Body lift problem! for all you 2" lift guys!
  • 8 Replies
  • 1638 Views
Offline BIG DOG
  • 105
« on: March 07, 2008, 06:17:59 PM »
I was following the instructions on Zuwharrie to do the lift on my 95 2dr 16V 5spd tracker and I ran into a snag! I'm putting on a 2" body lift with 2" tubing I got 2" bolts but they won't fit in the 2" tubing...DUH ! I should have figured that out!.I believe that I need 1 1/2" bolts so they will fit inside of the tubing and go through the hole on the bottom.My question is will 1 1/2" be long enough to get the bolt on and will it work ?There only seems to be the tubing and about 1/2-3/4 of a inch in the frame to consider. Also will the body bolt be bottoming out or interfering with the bottom of the tubing where it is only 2" tubing?
Thanks!
« Last Edit: March 08, 2008, 06:42:31 AM by BIG DOG »
Some of the dumbest people I know seem to know everything.........Funny about that!
Offline big_kountry21
  • 415
  • 1 bad mamajama
Re: Body lift problem!
« Reply #1 on: March 07, 2008, 06:23:30 PM »
i got the 3" calmini body lift and it came with 1 1/2 inch bolts.
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
Offline BIG DOG
  • 105
« Reply #2 on: March 07, 2008, 06:27:31 PM »
Is the calmini lift square tubing? I thought it was rubber! If so how far down from the inside of the square tubing does the original body bolt go I don't want to have to trim it if I can avoid it!
Thanks!
  • 415
  • 1 bad mamajama
« Reply #3 on: March 07, 2008, 06:45:59 PM »
its a piece of square tubing with an aluminum spacer
Offline BIG DOG
  • 105
« Reply #4 on: March 07, 2008, 07:00:47 PM »
So how far down from the inside of the square tubing does the original body bolt go I don't want to have to trim it if I can avoid it!
Thanks!
  • 415
  • 1 bad mamajama
« Reply #5 on: March 07, 2008, 07:13:46 PM »
i think like a half inch but there's a 1 inch spacer between square tubing and body
Offline BIG DOG
  • 105
Re: Body lift problem! for all you 2" lift guys!
« Reply #6 on: March 08, 2008, 09:05:52 AM »
So I guess I don't get it what are you guys doing that have 1 1/8" or 2" body lifts ? I see you have them but how did you put them on?Looks to me like I will have to modify the body bolts to fit! I don't see any other way! Or am I missing something?The body bolts will hit the bottom side of the 2" suare tubing I'm sure and if it doesn't there won't be any room for the 1/2" bolt head for the tubing to frame.....WHAT AM I MISSING!!!
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: March 08, 2008, 10:49:37 AM »
Put the rubber puck between the body and the tube. It will help
Offline BIG DOG
  • 105
« Reply #8 on: March 08, 2008, 11:29:54 AM »
What rubber puck? The body puck I thought that was the way it went. Body puck tubing under washer/rubber washer then nut.
