Need help: Reverse lights don't work
rottyfan
15
I love YaBB 1G - SP1!
September 22, 2004, 08:38:44 AM »
Hi,
I wanted to check in as a new (to me) Tracker owner. I recently acquired a 98 2 door 4wd convertable for my wife to use as a station car. The car is completely stock and the only modification is a Putnam hitch I installed last week.
The only problem I have found is that the reverse lights do not stay lit. The tranny is an auto and when I shift from park to reverse, the reverse lights briefly light up and then go out. I know the bulbs are good, so is the problem in the shifter? Any help or advice you can offer is appreciated.
Cheers
Annoy a Liberal:
Work, Succeed, Be Happy
explosivo
3157
I'm in the northern part of that one state.
Re: Need help: Reverse lights don't work
September 22, 2004, 08:44:50 AM »
Isn't there a switch for them on the shifter. I'd assume that's where the problem lies if they flash on for a moment and then turn off.
omghi2.us[/url]
Its a ZUKI thing. Doing more with less than less with more.
" -- HotRod
Cwkick
888
September 22, 2004, 09:08:14 AM »
I would say the switch or the shifter are out of alignment causing the to NOT stay on when in reverse.
Auto's have a cable and the cable may need to be adjusted.
Cwkick
wildgoody
8134
67
Reply #3 on:
September 22, 2004, 02:12:35 PM »
I have an Auto Trans too, and shifting
from P to R the lights don't light up, but
shifting from D to R they work, it must be
an adjustment, but I don't remember if it's
on the shifter, or a switch in the Trans
Baloo
84
Reply #4 on:
September 23, 2004, 12:55:32 AM »
???HI while we are on r-lights mine cuase the fuse to blow is this a common problem? I pulled the plug at the trany and have not had time to dig in yet. Thanks :-/
