calmini 6 inch combo question
  • 38 Replies
  • 7852 Views
Offline zukcrewcab
  • 26
« on: July 27, 2008, 06:53:06 AM »
I just installed a calmini 6 inch combo lift, with 32 swampers like they recomended and they rub on the inside fender well really bad.  they car is a 4 door and it is sagging in the front at least 1 1/2.  any body have any experience with this problem with this lift or a solution other than cutting??
Re: calmini 6 inch combo question
« Reply #1 on: July 27, 2008, 07:20:18 AM »
Have you asked Calmini? Its unusual for it to be down at the front, are you running a winch bumper or other heavy stuff on the front?
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: July 27, 2008, 11:58:56 AM »
We need more information:
Tire width
Rim width
Rim backspacing
« Reply #3 on: July 27, 2008, 04:11:24 PM »
Pics alswqays help
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #4 on: July 27, 2008, 05:44:33 PM »
bent shock towers :o
Offline zukcrewcab
  • 26
« Reply #5 on: July 27, 2008, 07:42:57 PM »
It has 15x8 2.5 backspacing, 32X10.50x15 swamper  tsl radials, bent shock towers are out of the question. what do you think?
Offline zukcrewcab
  • 26
« Reply #6 on: July 27, 2008, 07:44:19 PM »
oh yea, It does not have a bumper on it yet, so when that happens I'm gonna have a real problem.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #7 on: July 28, 2008, 09:17:46 AM »
my 2 door was doing that, pop the hood and shake the car side to side watching the inner towers through the hole of the outer towers, and check if they are centered, mine caused tonz of fuss wheels rubbing front sagging pulled to the left, tire towed in at top, just check if the lift is installed correctly it should sit perfect like this
Offline MUD CHILD
  • 355
  • 9
« Reply #8 on: July 28, 2008, 11:38:27 AM »
I'm running the six inch lift combo with 32x9.50 tsl's on 15x7 with 2.5" backspace rims. I had to cut the back of the fenders, the tires would rub when I turned. As far as the front springs go they are SHIT!!! I am on my second set now in 7 months the first set sagged out so badly that all but one coil on the spring would bind together. It wore all the powder coating off between the coils as they were coil bound any time i used it off road. As far as ride height with both set of springs it sits low in the front.
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Online RJkick
  • 632
« Reply #9 on: July 28, 2008, 01:01:50 PM »
I have a '92 4 dr with 15x8 rims with 3.75 backspacing and 15X10.5 XTerrains.  They only rubbed at full turn but a little hammer to the inner wheel well and that was gone.  As for the front springs mine do not droop but the back has coil bind over the little drainage dip between streets.  At about 15 mph or if I am going over whoops in the desert.  What can you do
Offline Foot
  • 76
  • Nothin Like It
« Reply #10 on: July 28, 2008, 05:29:47 PM »
Not enough backspacing is your problem. 3.75 or better should take care of it. 8)
HIT IT !!
Offline zukcrewcab
  • 26
« Reply #11 on: July 28, 2008, 06:51:16 PM »
 they call for minimum backspacing on the wheels , thats why I went with 2 1/2 on mine.  I am going to take pics and send them to calmini, because I have not even driven the car yet and I am having this problem.  what do you think about coil spacers  on the calmini coils, I can't live with the car sitting stink bug!!!
« Reply #12 on: July 29, 2008, 01:34:14 PM »
The problem is manufacturers of tires are allowed too much slack. Most 31" tires are really 30, and sometimes even 29" tires  >:( So, it's hard to say what lifts will clear what tires... it just depends on the brand, and if they're "really" the size they claim to be. With all the government regulation out there, i'm a little shocked this has been permitted for so long.
Offline Amilla
  • 1076
« Reply #13 on: July 29, 2008, 02:55:38 PM »
2.5" backspacing is a pretty hung for a rim, it should stick out quite a bit more than stock.
The lower the number the more it sticks out
2.5 stick out more than 3.75
Amilla
Offline Z71Edge
  • 87
« Reply #14 on: July 30, 2008, 04:40:07 AM »
I wonder if by "minimum" backspacing they meant to stick as close to the stock backspacing as possible. If thats the case, they should clarify that a little better for people so that this issue doesn't happen.
« Last Edit: July 30, 2008, 04:41:42 AM by Z71Edge »
93 Tracker, 1.6L 5spd, 235's on stockers for now...
