Calmini Kit
Calmini Kit
mhunterff49
20
Calmini Kit
August 12, 2009, 09:36:26 AM »
I just heard that someone modified a calmini suspension lift to work with their sport, does anybody know who that could be and if that is true?
DaddyDave
204
Indeed
Re: Calmini Kit
August 12, 2009, 09:48:47 AM »
Who did you just hear it from? I would start checking there
"The maximum effective range of an excuse is 0.0 meters."
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: Calmini Kit
August 12, 2009, 12:59:00 PM »
I said in an earlier post that I believe that one of the Aussies (CJ?) did this. It was on this forum.
Edit: The search on here doesn't work very well but you can use Googles advanced search. I had a quick look and found this:
http://www.zukiworld.com/forum/index.php?topic=10803.0
The V6 was fitted to non-US models.
Last Edit: August 12, 2009, 01:04:19 PM by Rhinoman
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
cj
1276
I drive a really big ATV
Re: Calmini Kit
Reply #3 on:
August 13, 2009, 06:36:15 AM »
The only difference is the two front diff drop brackets and I modded mine to suit. Calmini do have the specs for them courtesy of ZeusZuki. You will need to get a couple of the removable front ball joints for the front arms too.
