Calmini 2" or 3" kit?
  • 11 Replies
  • 2779 Views
Offline TysonS
  • 383
  • www.funinbc.com
Offline Agent Orange
  • 711
    • Trying to learn
Re: Calmini 2" or 3" kit?
« Reply #1 on: July 27, 2006, 08:34:14 AM »
2"
« Reply #2 on: July 27, 2006, 09:08:23 AM »
With the truss and could that be an RR 2" bodylift in the box too?
Offline FNG
  • 197
  • 91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
« Reply #3 on: July 27, 2006, 11:08:11 AM »
The control arms do not look like calmini,and the shocks and struts don't either.Clamini's 3"
kit comes with rear trailing arms andtop pivot mount for the rear end.
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #4 on: July 27, 2006, 12:48:06 PM »
i know that some of the kit is missing and trying to be found at the moment.  Yes, there is a 2" body lift in the box.  So the arms look like 2" or 3" ones?
Offline Speedracer7c
  • 2210
« Reply #5 on: July 27, 2006, 02:11:02 PM »
The 2 inch and 3 inch calmini lift use the same a arms. That is a 2 calmini lift and the a arms are obviously unmistakeably calmini......
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #6 on: July 27, 2006, 02:35:25 PM »
ok, thanks boys
« Reply #7 on: July 27, 2006, 03:05:49 PM »
Thay look like Calmini arms, the shocks and struts may not be the Calmini supplied ones but it looks like its had some use.  The struts have the mounts flipped and you can see the insert that is supplied with the 2" kit to go between the strut mount and the stut tower. I can't see any diff drop brackets though.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #8 on: July 27, 2006, 05:44:31 PM »
It's an older Calmini 2" kit, the stabilizer is the older round tube style that was included with the kit, not separate. The black springs are stock front springs as their 2" lift is built into the control arms and use stock springs. And as was mentioned, no rear control arms, just springs.
Offline DaddyDave
  • 204
  • Indeed
« Reply #9 on: July 27, 2006, 07:26:14 PM »
Actually, they do not.  Both arms are different.  They look "similar" to the untrained eye, but they are most certainly not the same arm.
"The maximum effective range of an excuse is 0.0 meters."
Offline ZeusZuki
  • 411
« Reply #10 on: July 28, 2006, 02:14:05 AM »
That is most definitely a Calmini 2" lift kit. The arms are shorter width wise than the 3" kit.
Go to Calmini's site and take a real close look and you will see what I mean.
ZeusZuki  8)
« Reply #11 on: July 28, 2006, 02:26:02 AM »
To my 'untrained eye' they look pretty much the same
