1.6 head spec ?'s
  • 1296 Views
Offline Zuki One
  • 441
    • ZUKI - PICS
1.6 head spec ?'s
« on: June 20, 2005, 05:23:58 PM »
Stock 1.6 head  spring pressure? spring height?
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Offline Zuki One
  • 441
    • ZUKI - PICS
Re: 1.6 head spec ?'s
« Reply #1 on: June 21, 2005, 09:51:59 AM »
btt
« Reply #2 on: June 22, 2005, 08:36:19 AM »
Valve spring free length:
                Standard, 50.46mm (1.9866in)
                Service limit 48.5mm (1.9094in).
Valve spring preload:
                 Standard, 24.8-29.2kg for 41.5mm (54.7-                  64.3lb/1.63in)
                 Service Limit, 22.8kg for 41.5mm  (50.2lb/1.63in)
Personally I wouldn't use anything outside of the limits for a new part. I have had bad experiences in the past with parts that were supposedly still servicable. It seems that you get a bit more wear each time the parts are disturbed because they need to break in a little bit again and that then takes them past the limit.
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #3 on: June 22, 2005, 04:31:44 PM »
Thank you! ;D
