can i make my own suspension lift?
  • 16 Replies
  • 6918 Views
Offline trizacker
  • 37
  • Every Cowboy needs a SIDEKICK!!
« on: April 12, 2005, 01:37:12 AM »
If anyone knows how to make atleast a 3" suspension lift please tell me all the details. Thanks
  • 6589
Re: can i make my own suspension lift?
« Reply #1 on: April 12, 2005, 01:42:29 AM »
Use the search button, dig into the suspension threads, look at the pictures, read the problems and solutions, go to the Article Archive and read the technical threads regarding suspension, come back with specific questions.
By the way... 3" suspension for what?
« Last Edit: April 12, 2005, 01:42:59 AM by ebewley »
Offline Natebert
  • 1098
« Reply #2 on: April 12, 2005, 03:24:02 AM »
Sure you can make your own lift.
Heck, you can make your own entire suspension system if you're creative enough.
Lots of people on here have posted lots of great ideas of all sorts to take a stock vehicle higher in the air, usually to fit larger tires or to get more ground clearance.
What kind of vehicle do you have?  Is it front wheel drive or rear wheel drive?  Is it 2wd or 4wd?  Do you drive an Arieo, Forenza, or a Sammy, for example?
There are lots of things you can do to lift something.
Give us some more info and we'd love to help you out.
~Nate
Offline trizacker
  • 37
« Reply #3 on: April 13, 2005, 01:25:35 AM »
I have a 91 suzuki sidekick 4x4
Offline trizacker
  • 37
« Reply #4 on: April 13, 2005, 01:37:18 AM »
I need to know the specs for the control arms, front axle drop brackets, strut spacers, extended rear trailing arms, rear V-Bar. Every thing to make my own home made calmini kit pretty much
Offline chet
  • 556
  • Zuki time!
« Reply #5 on: April 13, 2005, 03:12:34 AM »
your not going to find that info anywhere! The best you can do is use some different coils or coil spacers and figure the rest out yourself.
By the time you finish building all the calmini components it would have been cheaper just to buy it from them.
Offline 92Sidekick4x4
  • 1456
« Reply #6 on: April 13, 2005, 03:34:26 AM »
unless he owns a machine shop ;)
Offline BEETLE-TRIZ
  • 17
  • I love YaBB 1G - SP1!
« Reply #7 on: April 13, 2005, 03:42:13 AM »
as long as we get tht steel then you can build a 20 inch lift faggot ;D ;D
  • 6589
« Reply #8 on: April 13, 2005, 03:48:07 AM »
Whoa! Eventhough Trizacker's initial question is definitely noob-esque. This type of reply is not acceptable.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #9 on: April 13, 2005, 07:13:54 AM »
what forum do call home. that is not a good response for this one we try to help not piss people off. many of us have differrent ideas on how do things that is why i like this forum so much.
to ur question by the time u put in all the time on fab work and the expense on steel and welding rods u could hve bought the calmini kit and a set of tires and been wheeling for a couple of weeks. save up the money and get the calmini kit or go a little more conservitive with some spacers, a body lift, and a set of 31's and learn what a tracker can do on 31s that a jeep can't on 35s. WELCOME to the world of doing more with less. oh lock the rear and it will go anywher until u get stuck :).
« Last Edit: April 13, 2005, 07:14:46 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
mudfkr
« Reply #10 on: April 13, 2005, 07:52:58 AM »
Well I have a full machine shop at work and a garage at home equipped with lathe,chop saw, MIG welders etc etc and I'd say it's still not worth my time and effort to sit down and build my own from scratch !
If you had a kit to copy (BTW which I'd never do !) it would be a piece of p!ss to do but starting from nothing and getting to right the first time - Yeah right !!
Buy the Calmini kit and save ya $$$ and time experimenting.
Offline Cwkick
  • 888
« Reply #11 on: April 13, 2005, 10:06:27 AM »
Here is an inexpensive way of doing it.
Thank you Heather!
http://www.zuwharrie.com/content/view/11/27/
Cwkick
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #12 on: April 13, 2005, 11:07:16 AM »
Do a search and look at what Wildgoody has done for a 3" suspension lift. Cheap and effective and you could do it quick and be out wheeling.
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #13 on: April 13, 2005, 01:09:25 PM »
Im sellin a calmini 3" suspension and axles, and locker relativly cheap..... make an offer  ;D
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=forsale;action=display;num=1112677761
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #14 on: April 13, 2005, 04:12:28 PM »
Building suspension components can be life threatening if it is not built just right. If you plan on streeting this I would buy a kit.
Mike
