can you keep abs when switching to 5.13 gears?
4njeep
113
I Love ZUKIWORLD!!!!
July 26, 2006, 05:58:01 PM »
im putting in a 5.13 3rd in my auto sidekick, just wondering if there is a way to keep the abs working ? or is it going to affect it not having the speed sensor hooked up?
please let me know. im doing this right now.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Speedracer7c
2210
Guess she ain't stock no more!
Re: can you keep abs when switching to 5.13 gears?
July 26, 2006, 06:31:48 PM »
Does the 3rd with the 5.12's your putting in have provisions for the RWAL sensor in the housing? Im assuming it doesnt, In order to have abs you would have to swap all the parts from the 5.12 housing to the 4.62 housing. Which you wouldnt be able to do unless you had a install kit. However I just left my abs disconnected. It threw the brake light on in the dash but I just unplugged the ABS sensor under the dash and it went away. The abs sucks more or less anyway. HTH. Andrew
4njeep
113
July 26, 2006, 07:41:01 PM »
ok, thats what i thought, thanks
where abouts it the abs sensor under the dash. i am going to unplug that then
2" suspension lift
Speedracer7c
2210
Reply #3 on:
July 27, 2006, 06:52:59 PM »
Its right behind the brake pedal up on the firewall a little bit. Just a little black box. If you cant find it I'll snap a picture for you. HTH, Andrew
4njeep
113
Reply #4 on:
July 27, 2006, 07:45:48 PM »
i found it thanks,
does that black box control anything else besides the abs? just seemed like there was alot of wires coming out of it.
2" suspension lift
wolf66
193
Reply #5 on:
July 28, 2006, 03:24:19 PM »
hmmm, i did a 4.62 to 5.12 switch in my '96 and the ABS still works fine, and i've gone from 24" tires to 30" tires and it still works OK.. but i took the 3erd's to my mechanic and he installed him so no idea what he did to make the ABS work...
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
4njeep
113
Reply #6 on:
July 28, 2006, 06:15:19 PM »
the 5.13 3rd that i had, didnt have a sensor for the abs. and i didnt have a install kit, so i couldnt switch everything in the housing over. thats all. but it works fine without the abs.
2" suspension lift
