Carb options for a 87 Samurai
  • 5504 Views
« on: February 25, 2009, 09:23:16 AM »
I just bought an 87 Samurai. It is crazy hard to start in the mornings. I was told by some people that the stock carb is not very good. One guy I talked to here locally said to put an Empi Carb on. I don't have $400 bucks for a carb. Is there a cheaper option? Thanks guys Also how many hours to put on a new set of piston rings?
  • 6593
Re: Carb options for a 87 Samurai
« Reply #1 on: February 25, 2009, 09:34:16 AM »
The stock carb is actually not that bad. It gets a bad wrap sometimes because people mis-adjust it or there are other problems with the vehicle. In my opinion :)  Grab a maintenance manual for your rig and read about the carburator. One of the first things that gets people is that there are two idle settings. It could be as simple as those are mis-adjusted...  Good luck.
If you give up, the weber / empi carb... the 32/36 DGAV carburator can be purchased new for far less than $400.
« Reply #2 on: February 25, 2009, 09:50:03 AM »
That is some good info. Thank you. I just got a Haynes Manual for it.
Offline Spinnaker
  • 19
« Reply #3 on: February 25, 2009, 01:12:52 PM »
I built my own Harley CV carb setup and I've been very happy with it.  Easy to tune and runs very strong compared to my stock cab that was it good condition.
  ______
 /l ,[____],
 l---L |OlllllO|
()))()))-o-)))  Why don't they build the whole plane out of that black box material?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #4 on: February 25, 2009, 07:57:53 PM »
EWWWW!
Try the Factory Service Manual (FSM) downloadable at Ack's FAQ - search for fsm.
Also, here are a few links from the search engine that might be of use:
http://www.zuwharrie.com/component/option,com_smf/Itemid,40/topic,21551
http://bbs.zuwharrie.com/content/topic,31520.0.html
http://www.acksfaq.com/Samvacuumlines.htm
I hope that this helps!
Ack
Offline Zuken
  • 19
« Reply #5 on: February 26, 2009, 08:12:15 PM »
I think that the stock carb is much maligned because too many tinkerers (to quote ACK) have messed around without using the FSM and made things worse.  This is not the old simple Chevy two barrel of the 50's and 60's.  It is reasonably complex.  I would suggest immediately replacing all of the small vacuum hoses if you haven't already.  That is very low cost and may correct a number of ills.  I have read a number of posts from people who are not happy with the Weber or other replacement carbs and that costs bucks.  If you are not a skilled carb mechanic, then look up a good, reputable Carb shop in your area.  I took mine to a guy who has beautifully overhauled several of my Quadrajet 4 barrel Chevy carbs before, and for about a $100 + tab, my stock 88 carb is back to full health and it starts and runs like a new Sammy.  Just my 2 cents worth.   :)
88 Samiurai, SPOA 6 inch lift, 3.5" Bonz Shackles, Rear EZ lockers, 4.16 gears, Calmini OTS steering, 31" Truxus tires, Tri Mil header, Cherry Bomb, 2 " exhaust, RRO Front Bumper, extended shocks and shock mounts, Rock Biters, TT skid plate
« Reply #6 on: February 26, 2009, 08:21:20 PM »
Yeah I am far from a skilled carb mechanic. And carb scare me, so I may have to take it in to someone
