Kick Wont Start.
  • 8 Replies
  • 3715 Views
Offline tremendous
  • 20
  • I gave him a tremendous beating!
Kick Wont Start.
« on: July 02, 2005, 12:35:42 PM »
Hello ZUKFREAKS, I got a problem. My '97 Sidekick Sport won't start. My starter and spark plugs were changed last year. I changed my oil, oil filter, air filter and battery just yesterday. I need to get it boosted each time. I get this problem in the winter, when it is really cold and in the summer when it is really hot and humid. My buddy tells me I have an electrical problem, what do you guys think?
I love my Zuk!
So polluted!
Offline Chief
  • 678
  • Whaddya lookin at??
Re: Kick Wont Start.
« Reply #1 on: July 02, 2005, 01:07:07 PM »
I'd say go get your alt checked. If it checks out fine, I would think you have a grounded wire somewhere, and need to start tracing wires to find it..... :-/
Offline Suzuki1.8
  • 283
« Reply #2 on: July 02, 2005, 02:41:59 PM »
I WOULD SAY GET YOUR STARTER SOLENOID CHECK. Take the starter down to a local part store and have it checked out. Suzukis are famous for bad solenoids.
Offline tremendous
  • 20
« Reply #3 on: July 02, 2005, 04:28:27 PM »
Thanks a bunch for the tips.
So polluted!
Offline Mythose
  • 361
« Reply #4 on: July 02, 2005, 04:55:24 PM »
Its your battery cabels,  it it changes by enviroment chances are you need new battery cables, rally simple test, just call and find the resistance peramiters, and ch3eck it with ta volt meter.
Offline Mythose
  • 361
« Reply #5 on: July 02, 2005, 04:57:37 PM »
Also does it crank slower then usual, when the motor gets hot? that is a good sign of a bad battery cable or a bad Ground, check for corosion and rust.
Offline tremendous
  • 20
« Reply #6 on: July 03, 2005, 12:46:57 AM »
I don't think it is my battery cables, they are in pretty good shape. My Zuk is super clean even under the hood. No rust or corrosion, but it does crank slower than usual.
So polluted!
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
« Reply #7 on: July 03, 2005, 02:49:56 AM »
If you checked the battery terminals, and they are clean, make sure you check the connections on the starter as well.
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
Offline twistedthrottle
« Reply #8 on: May 07, 2010, 02:39:13 PM »
I've heard that the cold side of the ecm can go out causing you exact symptoms.
