changing headlights on an 88 samurai
  • 3230 Views
« on: October 26, 2008, 08:19:01 PM »
there are two screws that are visible from the outside but i believe those are for adusting the lamp. does anyone know how i actually change  the whole headlight? it's not just a bulb thing. thank you
Offline SNJSamurai
  • 386
Re: changing headlights on an 88 samurai
« Reply #1 on: October 26, 2008, 09:07:00 PM »
got to remove the grill. theres a screw in the middle of the grill and u kinda flex the grill out theres little pins on each side that helps hold it in.
   then youll see what holds the head lights in
Bob
Offline Merlin93
« Reply #2 on: October 27, 2008, 08:54:08 AM »
Headlights have a very uniform wearout characteristic.  If one has failed, the other cannot be far behind.  Given your your time & labor, it makes sense to replace both headlights at the same time, even if only one is out now.
« Reply #3 on: October 27, 2008, 09:17:02 PM »
thanks for all you help so far folks, it's much appreciated. I just got the headlights today so I'm going to give it a rip tomorrow.
Offline SNJSamurai
  • 386
« Reply #4 on: October 27, 2008, 11:09:57 PM »
also check out the connection. these awesome trucks are old so corrosion and dirt get in there threw out the years  :-\ and can cause to have a poor connection and headlight not work well.
 autozone has replacement connectors if they are real bad.
and some electric grease can help keep the moisture and dirt out too
Bob
