check engine light
  • 1 Replies
  • 1109 Views
Offline Bfunk
  • 406
check engine light
« on: October 24, 2009, 07:48:26 PM »
Do the OBDII motors have the little switch that the OBDI motors have to turn off the light ???  In other words will a 97 2 door have the switch up under the dash, and if so is it in the same place?  Thanks all
Brian
Offline fuzzy1
  • 350
Re: check engine light
« Reply #1 on: October 25, 2009, 10:16:26 AM »
No, the later models don't have the 'nag' switch. If CEL is on running, it's a real code. Any parts store will let you use a code reader if you don't have one. hth
Fuzz
Non Illegitimi Conterat
