choke question
  • 1954 Views
Offline ronwsh8
  • 22
  • I love YaBB 1G - SP1!
choke question
« on: July 17, 2005, 11:25:02 AM »
when the engine is at operating temp and you take off the air cleaner top off should the choke be fully open (straight up) mine is 3/4 closed at all times i'm thinking this is why i failed smog test at 2500 rpm's but not idle
Re: choke question
« Reply #1 on: July 17, 2005, 01:37:23 PM »
And the "smog tech" couldn't see/tell
you this??? , I would think of going
someplace else, unless they are going
to test again for free
Offline ronwsh8
  • 22
Re: choke question
« Reply #2 on: July 17, 2005, 01:42:54 PM »
he never took the air cleaner off i asked him if it could be the choke sticking he said no did'nt check the chike till this morning and found the problem
Re: choke question
« Reply #3 on: July 17, 2005, 01:45:10 PM »
Sounds like he was trying to get more $$ out of you
Offline ronwsh8
  • 22
Re: choke question
« Reply #4 on: July 17, 2005, 01:51:48 PM »
i'm gonna take it to someone else tommorrow and hopefully this fixed it and it will pass
Offline zaggy
  • 1134
Re: choke question
« Reply #5 on: July 17, 2005, 02:03:31 PM »
Kinda thought so from the symptoms......you can set it yourself!!!
Zag
Offline ronwsh8
  • 22
Re: choke question
« Reply #6 on: July 17, 2005, 03:51:05 PM »
i tryed to set it the marks lined up but the choke still would not open i must have something bent in the linkage someware i'm gonna smog it then buy a weber carb anyway thx for the help everyone cross your fingers hope it passes smog tommorrow
