swift engine?
  • 2050 Views
Offline zukzilla1662
  • 90
swift engine?
« on: September 08, 2006, 06:28:38 PM »
can i put a swift engine in my samurai........if i can what do i have to do???
Offline tdspence
  • 45
Re: swift engine?
« Reply #1 on: September 08, 2006, 08:49:47 PM »
Yes, depends on which engine your talking about on what you have to do. For the DOHC you will need the ECM, wiring harness, and a custom header or you can modify a motor mount to make the stock exhaust manifold fit. The dist will also be facing the wrong way so you will need to cut a whole in the firewall, buy an adapter for lots of bucks, or modify your dist and rotor to take a mazda 323 cap and rotor. Also probably a few other odds and ends too.
http://home.iprimus.com.au/pulsr/g13b/
http://www.suzisport.com/shop/  (they sell the adapter)
Offline tdspence
  • 45
Re: swift engine?
« Reply #2 on: September 08, 2006, 08:54:20 PM »
Also, this site had a lot of info about the DOHC engine.
http://www.ado13.com/dohczuke/dohc.htm
  • 90
Re: swift engine?
« Reply #3 on: September 08, 2006, 10:33:46 PM »
thanks how much does the swap cost and can i use the same tranny
Offline tdspence
  • 45
Re: swift engine?
« Reply #4 on: September 08, 2006, 11:51:44 PM »
It bolts to the samurai tranny, not sure how much the swap cost because it was already done on mine before I bought it. I think it would mainly just depend on how much you could get the engine for.
