RACK on RAG
RACK on RAG
PYRO
16
I Love ZUKIWORLD!
RACK on RAG
January 16, 2006, 03:14:04 PM »
Hey guys any one with ideas how to install a custom rack on a soft top? Without messing with top it and still be capable to go off-roading with stuff on rack? I mean where do you recommend to support the weight of the rack?
94track
212
Re: RACK on RAG
January 16, 2006, 03:49:06 PM »
I would just do some searching around. What you wheelin a sammi or trackick
http://www.puresuzuki.com/safarirack.htm
http://www.puresuzuki.com/roof_rack.htm
both are generally the same mounting points,except sammi has 2 mounts running down to the cowl, depending what you have I would prolly mock something up close to this, or just search around and see what other people/companies have
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: RACK on RAG
January 17, 2006, 04:57:10 AM »
I fitted a rack to mine some time ago. If you have a look on my site under mods there is an article that shows where all the mounting points are. I used a set of genuine Suzuki roof bars, the mounting points are all on the vehicle you just need to know where to look
http://www.rhinoman.org
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
