pulling front 3rd member on ifs models
  • 1950 Views
Offline Maroon Monsoon
  • 876
« on: July 01, 2006, 10:28:13 PM »
I have a 2000 GV but the diff should be quite similar to kicks and X 90's for the front. how do I get the third out without messing anything up? my dad and I messed up the snap ring in the passenger side of it and messed up the seal and potentially a dinger on the CV when we put the lift on. now I took the passenger side back apart to try and fix it. the snap ring is lost in the diff and a friend of mine said it had to come out so the diff is removed and I'm not sure now to get the longer axle shaft out without messing it up (probably prying like the CV on the other side?) and need a good method on how to break apart the glue type stuff that seals the 3rd to the housing
any input is appreciated, thanks allot
I'm not having a good evening
  • 876
Re: pulling front 3rd member on ifs models
« Reply #1 on: July 01, 2006, 11:19:51 PM »
also wondering if I could run a calmnini anvil with my 1.5 coil spacers on my GV. lifted it about 2 inches up front. I might need a new CV anyway and it would be damn nice to have both sides flanged
Offline da_tub
  • 307
« Reply #2 on: July 01, 2006, 11:37:23 PM »
it's in there quite snug . you have to use like a dead blow hammer, or if you don't have that  use a hammer with a block of wood and give it a good whack. might take a few ,, but it will let go... good luck... dwayne
91 four door ,and some stuff
  • 876
« Reply #3 on: July 01, 2006, 11:48:52 PM »
I do have to take the longer axle shaft out first right?
thanks
I have a deadblow hammer so I should be in luck
« Reply #4 on: July 02, 2006, 06:50:20 AM »
Yeah, you need a slide hammer for that one.
  • 876
« Reply #5 on: July 02, 2006, 05:47:32 PM »
got the shaft out with a dead blow hammer and a pry  bar. the third then came right out. hope everything will be alright. all I need is an axle mount bolt that I stripped when I removed it. (the big top drivers side one) I don't think I should drive it till I get that part. hope the dealership will have one in stock.
I really wish I would have gone with a calmini kit and had all the drop brackets and control arms as well as .5 to 1 inch more of lift.
thanks for the help
