u bolts
  • 1703 Views
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
u bolts
« on: November 23, 2007, 03:46:28 PM »
 What kind of u bolts are you diy spoa guys using on the samurais? The last time i did one i broke a few of the stock ones and had to use some generic tractor supply ones. They just were not compleatly right. Is there any tricks?
« Last Edit: November 23, 2007, 03:49:10 PM by brawnyrebel »
If its not broken, break it
kingzoo
Re: u bolts
« Reply #1 on: November 23, 2007, 04:20:30 PM »
   I get mine at napa,and I use grade 8 u bolts.tell them that the u bolts are for leaf springs,and what for.
Offline brawnyrebel
  • 131
Re: u bolts
« Reply #2 on: November 23, 2007, 07:21:04 PM »
Do they give you two different sizes for te front ones?
Re: u bolts
« Reply #3 on: November 24, 2007, 01:20:55 AM »
I run stock U-Bolts on the front.  on the rear I sleeved the axle with a thicker tube and picked up a set of custom U-Bolts to fit.  Then built a new pad to bolt themt o.
