steering with toyota sprung over axles
J-Ron
July 09, 2007, 11:39:30 AM »
if i put toy axles on with a spring over, is there any other alternative than the samurai to toyota high steer kit from sky-manufacturing? my budget is consuming me....
mrfuelish
2862
13
you must have a perception problem.
Re: steering with toyota sprung over axles
July 09, 2007, 01:01:53 PM »
Yes if your good at welding, take another arm and flip it upside down on the passenger side arm, bore the four holes bigger, and weld it to it, this is the short version but you can do a search.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
J-Ron
July 09, 2007, 08:27:52 PM »
wow, that's so ghetto it just might work! i would probably need a bigger pitman arm, right?
but now im looking at trail-gear and separate ordering all the parts which looks like its about a hundred bucks cheaper if im looking at the right parts...
wtrskier
Reply #3 on:
July 10, 2007, 08:56:46 AM »
find a newer power steering gear box off a toy at the bone yard.but then u have to fix steering colmn to fit
