crank shaft moving in to engine block
  • 1 Replies
  • 1171 Views
Offline Dazookster
  • 61
« on: September 28, 2007, 03:41:35 PM »
On my samurai it looks like the crank shaft is moving in to the engine block is this a normal samurai thing to have happen? what can i do to fix it?
Wahoo for Global Warming more time to go Wheeling
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
Re: crank shaft moving in to engine block
« Reply #1 on: September 28, 2007, 03:50:10 PM »
Visibly moving front to rear? you should probably pull the speck and measure its travel and invest in new bearings. Consider this a good thing like a good time to think about moving up to 1.6L.        NMc
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
