crown vic shocks?
  • 7 Replies
  • 5397 Views
Offline museboy07
  • 641
crown vic shocks?
« on: January 22, 2007, 08:00:51 PM »
whats the deal with ppl putting ford crown vic shocks on their track/kick? does this improve anything?
Re: crown vic shocks?
« Reply #1 on: January 22, 2007, 08:32:43 PM »
Mainly used for 3"inch suspinion budget lifts.
Or if you have an after market 3"inch suspinion lift and need new and cheap shocks
Offline PHX96TRACK
  • 90
« Reply #2 on: January 22, 2007, 09:07:07 PM »
Mostly from what I read they are used by budget lifters who use coil spacers. These shocks are cheap, they fit, and they are longer than stock Trackick shocks to compensate for the lift. These are ?-1991 shocks for a Ford Crown Victoria. The monroes are about $20. I was going to ask people what ones to buy....
« Last Edit: January 22, 2007, 09:09:01 PM by PHX96TRACK »
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
Offline museboy07
  • 641
« Reply #3 on: January 23, 2007, 12:30:32 PM »
so what all do i need for the 3 inch budget lift wit the crwn vic shocks for my 94 track
Offline WorkInProgress91
  • 31 gets it done
« Reply #4 on: January 23, 2007, 02:46:20 PM »
you will need a longer spring, or coil spacer to actually lift your vehicle.  the crown vic shocks do not add lift, they just are a bit longer than stock.  If you put a lift in the rear, the stock shocks will pull apart when the suspension flexes down, and pull apart.  There is a guy on here who sells coil spacers, and several vendors that sell them as well.
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #5 on: January 23, 2007, 03:25:03 PM »
To elaborate on the cheapo suspension lift concept:
Check out http://www.zuwharrie.com/content/view/11/27/1/0/ for a detailed description on how to do a 2" suspension lift. Although the article talks about lifting a 4-door, just about everything in it also applies to a 2-door.
Be sure to carefully read the article before running out in a buying frenzy to get the necessary parts.  This kind of lift is exactly what it says it is.  Cheap.  Which is to say that you are not gonna be able to do serious rock crawling.  The offroading qualities will improve (bigger tires, better ground clearance) but things will break if you really push your truck with this grade of suspension lift.  It'll take more money and effort to get to the next level.
There are a few threads both here at ZukiWorld and in the Tracker/Sidekick forum at Zuwharrie.com that can help you if you search.
Just in case you might think that I have two tricked up TracKicks in my collection, I don't.  Both are bone stock.  More importantly, I have two sets of spacers SCREAMING at me to install them in my trucks!  It's cheap, It'll add to the modest offroading habits that I have and it'll start me out down the road to turning them into offroad monsters (even better than my Samurai).
This is such an addictive hobby!
Ack
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #6 on: January 24, 2007, 04:38:35 PM »
I'm sorry, but after reading 6+ topics all asking the same exact type of questions all by the same person and all of the first or second page I have to say this...
Please search out the related topics posted previously before you ask something that most likely has been answered already, and several time over at that. I know for a fact from being personally invloved in such topics that ALL of your questions you have posted have been answered MANY, MANY times already...
I guess I'm just burned out and cranky right now, so like everybody nevermind... ::)
Offline Praise Him
  • 256
« Reply #7 on: January 24, 2007, 07:06:42 PM »
Just got to napa and buy 99 and up f250 shocks, there like 25 bucks, and bigger than calimin's
sammy/toy axles/locked/geared/cased/36's
