Samurai heat stove hose
  • 3204 Views
Offline erik the red
  • 174
    • Cascade Adventure Guides
« on: February 02, 2011, 07:17:33 PM »
What can I use as a replacement heat stove hose? O'Reilly Auto Parts and Autozone don't carry it and I'm not paying 45 bucks for a used one... :ohttp://www.samuraisalvage.com/itemdetail.asp?txtitemname=hose&Submit2=Go!&catid=&itemID=1080
Seems like any high heat resistant, flexible hose should work. Any thoughts?
1996 Geo Tracker
1987 Suzuki Samurai soft top
1987 Suzuki Samurai Tin Top
1972 Suzuki LJ20V
Re: Samurai heat stove hose
« Reply #1 on: February 02, 2011, 07:39:18 PM »
I got some reinforced silicone hose for my truck, mostly because
of the heat under the hood, silicone doesn't burn at 500* like
rubber hose will, and it doesn't stick to the fittings like rubber
either
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #2 on: February 06, 2011, 07:13:02 AM »
Other than the 1st few inches from the exhaust manifold heat shield radiator hose should work. A person could even use ABS / PVC / CPVC pipe if they wanted to use something more rigid. Current temps under the hood don't melt the exisiting hoses / wiring as long as a sensible distance is placed between them.
A good rule of thunb would be if you can't lay your hand on the surface then you shouldn't utilize a combustible material in against that area.
You might try a few local wrecking yards for the this diameter exhaust tube. They were used on other vehicles as well, and you may even get lucky. I stopped at a "out in the sticks" salvage yard last week and asked if they had any Suzuki SUV's. The fellow told me there was a sidekick out there if I wanted to take a look at it. I walked back and found it was a Tin Top - the 1.3 was gone. I bought a few parts from it including the hose you are refering to. (I gave a $1 for the hose)
Sometimes the sun shines on a dawgs hind-end......  :laugh:
« Last Edit: February 09, 2011, 03:42:49 PM by tuxblacray »
« Reply #3 on: February 07, 2011, 11:27:19 PM »
Did you grab the diff gears in that 1.3 tin top???
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #4 on: February 09, 2011, 03:54:11 PM »
Wild... to be honest it was 13 degrees and the wind was howling.The bottom 16" of the Tin Top was buried in the snow. I really didn't give it much of a once over. My real mission was to pick up some Toyota Camry parts. I will be heading back in the future to give it a 2nd look over.
« Reply #5 on: February 09, 2011, 06:58:38 PM »
Ya, well under those conditions, I think they can wait  :o
