Can I run 31/10.5 on my stock 1.6 kick 91'
  • 28 Replies
  • 3892 Views
Offline bioniconion
  • 268
  • I love YaBB 1G - SP1!
Re: Can I run 31/10.5 on my stock 1.6 kick 91'
« Reply #15 on: November 02, 2004, 08:00:17 AM »
emergency crash escape pod ;)
HAHAHAHAH! omg..that's hillarious. my tracker has 4 inches of body lift :) i wanna put 31's on it. but im having a little problem finding some cheap rims. any suggestions? also im kinda new to the tracker offroad thing but what would u guys suggest? :) im an open book
Offline 1bigtracker
  • 3409
« Reply #16 on: November 02, 2004, 08:40:47 AM »
You consider 4 1/2 inches of body lift to be a little?   :o
What do you think is going to happen to your body if your chassis hits something travelling at speed?
~daxe
It would be kinda like an Indy car when they hit a wall at a 150MPH.  all that left is the cockpit.  you said you had carbon fiber floors right? :-/
stu
stu
Offline explosivo
  • 3157
« Reply #17 on: November 02, 2004, 09:48:49 AM »
Old Bronco/F150 wheels... I currently have a set of 31" AT's off my Bronco mounted on the Tracker right now (had to drive it 250 miles home... needed something other than the biasply LTB's)
omghi2.us[/url]
Offline bioniconion
  • 268
« Reply #18 on: November 02, 2004, 10:23:19 AM »
so f150 wheels can handle a 31/10.50/r15 tire then? wow you guys are actually helpful unlike the guys on the eclipse forum*my other ride*
actually im going to call a junkyard tomorrow looking for these. what exactly should i ask for? year? model? etc? i really appreciate the help
« Last Edit: November 02, 2004, 10:30:05 AM by bioniconion »
Offline explosivo
  • 3157
« Reply #19 on: November 02, 2004, 11:06:17 AM »
Dunno... I bought my 1980 Bronco with 31's on what appear to be stock wheels... so I'd start there ;)
omghi2.us[/url]
« Reply #20 on: November 02, 2004, 12:30:36 PM »
Biggest thing is the center needs
to be 4-1/4" (105mm) to fit over the
front hubs and the rear caps.
Most early Ford trucks had this size
wheel on them, and will all fit 31x10.5
tires.
Offline explosivo
  • 3157
« Reply #21 on: November 02, 2004, 12:51:38 PM »
tires.
Oh yeah, one other thing: my '82 F-100 didn't have large enough center holes... dunno if that's because it was 2wd or what. :-/
omghi2.us[/url]
Offline bioniconion
  • 268
« Reply #22 on: November 02, 2004, 02:09:15 PM »
saweet! ill definately be calling the junkyard tomorrow! hehe
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #23 on: November 03, 2004, 12:03:57 AM »
 ::)Lot's of good info.  The Ford 1/2 ton (early) wheels are a great idea.   I got a set of 4 aluminum "10 hole" 5x5.5 15x8 for $100.00 in good shape.  The backspacing is good as well.  The early wheels have the same center hole size, but the 4x4 is a fairly certain fit.  The 31x10.5 are a great fit on that rim size.  Good luck. ;D
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline explosivo
  • 3157
« Reply #24 on: November 03, 2004, 05:40:37 AM »
Oh yeah, speaking of backspacing, the Bronco has 3.75" backspacing (assuming the pickups are the same), which gives you about a half inch less backspacing.
omghi2.us[/url]
Offline bioniconion
  • 268
« Reply #25 on: November 03, 2004, 06:12:28 AM »
WOOO! found 4 old f150 rims and need to paint them but i got all 4 for 20 bucks!  ;D ;D
Offline explosivo
  • 3157
« Reply #26 on: November 03, 2004, 10:38:13 AM »
Sweet. Pics, man, pics!
omghi2.us[/url]
Offline bioniconion
  • 268
« Reply #27 on: November 03, 2004, 02:26:37 PM »
Offline explosivo
  • 3157
« Reply #28 on: November 03, 2004, 02:32:14 PM »
http://us.f3.yahoofs.com/users/4188dfe9zecfa00dd/mail/__sr_/b670.jpg?ph1NbiBBbUMrgxQz
im working on sanding them down and painting them black :)
Sweet man... look just like my Bronco's wheels, 'cept mine are purty silver (spraypaint) ;D
Also, you can post images directly to the forums rather than links by uploading them here:
http://upload.eye-irritant.com/
omghi2.us[/url]
