how do you search for a topic
  • 9 Replies
  • 3193 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: June 03, 2005, 01:06:54 PM »
i m frustrated with this search engine. i  cant find how to install    the 3" calmini lift .  i typed everything that would be in the name and i get nothing or stuff that is not even related to the subject.  can someone help me? ??? ??? ??? ??? ??? ???
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline 1bigtracker
  • 3409
Re: how do you search for a topic
« Reply #1 on: June 03, 2005, 02:39:33 PM »
http://www.zukiworld.com/month_030101/feature_trickerkickersuspension_03.htm
this is the bosses(Eric) Tricker Kicker build up.  it has a Calmini 3in install on like page 3.
stu
Offline Cwkick
  • 888
« Reply #3 on: June 03, 2005, 02:41:05 PM »
DANG!  You beat me to it!   :P
Cwkick
Offline 1bigtracker
  • 3409
« Reply #4 on: June 03, 2005, 02:41:49 PM »
Cwkick
;D ;D ;D
« Reply #5 on: June 04, 2005, 10:00:19 AM »
I believe the search engine only searches the Forums. The menu at the bottom of the page takes you to the Tech Articles.
Offline wezzlegod
  • 227
« Reply #6 on: June 05, 2005, 11:45:48 AM »
thaks for the links
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #7 on: June 05, 2005, 01:52:46 PM »
AND   I am looking for what fix Mike H. made on his sis's rig that would only start on starting fluid.
Searching Searching searching searching searching searching....  Still Seaching
Offline SnoFalls
  • 1358
« Reply #8 on: June 06, 2005, 02:21:32 AM »
By default, the search only goes back 7 days ... so, change the "Max Age since last post" field to something like 90 (or more) to get older posts ...
Then again after that hacker, not much is left going back to far :(
« Reply #9 on: June 06, 2005, 04:12:00 AM »
He replaced the ECU
