diff removal
  • 1994 Views
Offline trup
diff removal
« on: January 13, 2006, 06:19:23 AM »
 ;D whats the easiest/simplest way to remove my whole front differential and axle housing assembly? will removing the 4 u-bolts enough??
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: diff removal
« Reply #1 on: January 13, 2006, 07:59:00 AM »
and sway bar if still connected also brake lines and shocks also driveline.
  what is the purpose of the pull?
Mean Green Wheeling Machine
Offline trup
Re: diff removal
« Reply #2 on: January 13, 2006, 08:05:51 AM »
thanks bash, my 410 still uses the original front drums :(, just want to upgrade to discs
  • 6589
Re: diff removal
« Reply #3 on: January 13, 2006, 08:22:56 AM »
Are you thinking of upgrading to disks by swapping the whole axle assembly from the SJ410 to a Samurai housing? This wouldn't be that easy to accomplish (is not a direct bolt in) because the axle perches are not in the same location. Also the Samurai axle is wider than the SJ410 so you would have a difference there. Also, the gearing is different your SJ410 as 3.93 or 4.10 gears (if I recall correct) and the Samurai has 3.73. However, I believe though that you can interchange all of the outer hub assembly and spindle with the disk brakes from a Samurai to the SJ410 axle assembly.
Another option would be to find a complete set up from an '85 they had disk brakes.
Hope this helps... -Eric
Offline trup
Re: diff removal
« Reply #4 on: January 14, 2006, 04:01:04 PM »
ebewley, i'll be using the axle assembly  from a later model 410, maybe it's from an 85 ;D, thanks
