do p235/75/15 tires really fit a stock track/kick?
  • 33 Replies
  • 22928 Views
Offline hickwheeler
  • 39
« on: July 31, 2007, 12:07:33 PM »
Alright I know this is a common topic but when I went to les schwab with my dad the other day they said p215/75/15 was the max tire size and maybe p225/75/15 with trimming. also that a 7'' rim was definately the biggest rim I could get. Now les schwab is not the main problem now my dad won't let me get p235/75/15's cause of what les schwab said. any support or ideas I could use to convice my dad would be appriciated. Maybe pics with p235's on a stock trac/kick. my tracker is a 96 if that makes a difference. Has anyone ran uniroyal liberator a/t's on a trac/kick thanks. And also to those of you who have ran p235's on a stock track/kick how did you get the tire shop to put them on? sorry for all the questions but I need advice.
Offline Jookycola
  • 372
Re: do p235/75/15 tires really fit a stock track/kick?
« Reply #1 on: July 31, 2007, 03:29:20 PM »
Yep, no problem fitting 235's at all.  and this is with a really far offset on these wheels.
But when i had the stock wheels, I never had a problem.  It definitely gives it a tougher stance.
  [/url]
Offline jzap
  • 515
  • How difficult can it be?
« Reply #2 on: August 01, 2007, 08:58:50 PM »
I believe that 235s will fit.  A guy that used to be on this board had Hitech 235 retreads on a stock '93 2dr.
I can tell you that 225s will definitely fit using stock rims.  I'm running 225 Dunlops on my '96 box stock Tracker.
Jim Z.
96 Tracker
66 Apache camper
Offline Jookycola
  • 372
« Reply #3 on: August 02, 2007, 07:54:53 AM »
Of course 235's fit.
I have 235/75/15's on my bone stock white tracker in both photos.
  [/url]
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #4 on: August 02, 2007, 07:57:32 AM »
the only thing is that the rears will rub just a bit if your at full flex....other than that no problems at all, i had the hi-tech retread 235/75/15's on my tracker before i put in the coil spacers
my truck rails harder than your girl
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: August 02, 2007, 09:17:47 AM »
If anything, a 235/75 is more accurate! I found with my 235/75's my spedometer was much closer to my Magellan GPS...
« Last Edit: August 02, 2007, 09:31:00 AM by Uncivilized »
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #6 on: August 02, 2007, 09:22:44 AM »
bone stock here with the 235's
with the 2" coil spacers and the 235's
« Last Edit: August 02, 2007, 09:25:19 AM by geeeeoooo »
« Reply #7 on: August 02, 2007, 11:20:59 AM »
I fit 235/75/15 on my stock 95.  I've run both Firestone MTs and BFG ATs on 7" wheels.  Both rubbed when flexing but the MTs were worse.  The amount of rubbing depends on the specific tire & wheel combo.  And like UnCivilized, my speedo checked with GPS is now dead on accurate!
Offline bus_driver
  • 479
« Reply #8 on: August 02, 2007, 11:35:17 AM »
ok that is hot a kick with a bikini lady in a river bed and a dog. just change the lady too a hot asian and that is my pic choice.....my wife is asian so you understand...oh and i run hercules terra trac mt that measure 9. something width and 29 inches tall on stock alluminum wheels and a 2 inch spacer lift. the only rubbing is on the front tires at the back side on the frame.. other than that there is no issues at all. and it runs alot nicer than stock size.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Jookycola
  • 372
« Reply #9 on: August 02, 2007, 12:24:54 PM »
Yeah i forgot to add that.  In extreme flex the rears will in fact rub.  I didn't think about it since mine is so stock i never rock climb or anything to extreme.  And it happens so rarely during just daily driving.
  [/url]
Offline muskegtracker
  • 273
  • 10
  • Mr T
« Reply #10 on: August 02, 2007, 12:53:17 PM »
235's on stock rims rub the frame.  But can be adjusted at steering stops located by steering link on each side of the frame.
91 Chevy Tracker
Offline Baloo
  • 84
  • I love YaBB 1G - SP1!
« Reply #11 on: August 02, 2007, 01:00:05 PM »
 ;DI have two sets of 235 75 15 on stock rims I have no rubs or other tire problems.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #12 on: August 03, 2007, 01:36:27 PM »
If you can find a set of stock Samurai wheels, they have .5" less backspacing(3.75")(stock is 4.25") setting the tire that much further from the frame. Doesn't seem like a lot, but it helps.
What vehicle are those wheels from? I've seen them on some Ford F150's, but not sure on year/model...
BTW - that purple looks cool in the sun ;)
Dave
« Reply #13 on: August 04, 2007, 07:20:46 AM »
Dave
Those wheels came off a Tracker we bought for parts but I've been told that early model F150 wheels will fit Trackers!  Thanks on the purple!
« Last Edit: August 04, 2007, 08:05:48 AM by LilRed »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #14 on: August 04, 2007, 07:13:06 PM »
I had absolutely minimal rub on the frame at full lock with 235-75 Dueler M/Ts on my stock '96.  All you'll get is a little shiny spot.  The pluses way outweigh that little negative.
Then put some small coil spacers in and you'll be gold.
XL-7 front coils
1.5" rear coil spacers
