The best shackles for on and off road use??
RiceBurner Turner
October 29, 2007, 05:22:01 PM »
What about folding shackles? Are they safe for on road use? I have heard shackle reversal kits can be very dangerous on the road, but I wanted to hear some other opinions. I want some flex off road, but I dont want to die going to the grocery store.
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Re: The best shackles for on and off road use??
October 29, 2007, 07:07:25 PM »
i've been running calmini's for 7 years now. i drive it everywhere. never had a problem.
looks alot better than shackle extensons sticking out there. my 2 cents
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
phloop
October 29, 2007, 08:45:27 PM »
And you don't have to worry about the handling of a shackle reversal on rode. Cars and trucks came from the factory with the shackle to the rear on the front springs for many years.
JoeCool
164
Carpe Noctum!
Reply #3 on:
October 29, 2007, 11:31:40 PM »
I saw a set of shackles on a heep once that had Teflon plates instead of pivots. the lower plate had a slot which the top had a pin able stud extending down through. On the street the pin would keep the rear of the leaves solid but able to slide front to rear. Off road pull the pins and the leaves drop away limited only by the shocks. Invest in hi angle u joints and a pan hard rod.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
