Drive shaft spacer
Drive shaft spacer
RHodge
523
Drive shaft spacer
February 16, 2007, 06:22:37 PM »
Is it better to put the space |removethispart|@ the t-cast or the diff
Ryan
HotRod
4334
2
95 Tracker
Re: Drive shaft spacer
February 16, 2007, 06:51:11 PM »
Good question but most of them are put on at the Dif.
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
February 16, 2007, 06:58:03 PM »
I was told t-case by a vendor
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
TysonS
383
www.funinbc.com
Reply #3 on:
February 16, 2007, 08:08:33 PM »
i don't know if this is the right way but i would put it at the tcase to stop from getting damaged by rocks and what not.
2 Dr. 91' 8v Sidekick| 3" Body Lift | 4" Gas Tank Lift | 3.5" Suspension Lift | Snorkel | Custom Bumpers | Sliders | 31" LTB's | Detroit | 4.24 Tcase | TT front locker soon
ack
1659
34
Professional askhole
Reply #4 on:
February 17, 2007, 12:06:40 AM »
I installed thinner spacers at both ends and have run my truck that way for about 6 years. Haven't lost a u-joint because of it yet... I DID lose a rear u-joint because I undertightened the flange bolts...
Ack
Ack's FAQ
http://www.acksfaq.com
Amilla
1076
Toyota running gear was made for a samurai!
Reply #5 on:
February 17, 2007, 12:39:22 PM »
Thats how i have seen people doing them. Just like ack said, spacers on both sides of the drive shaft. But i have seen it the other way to on the T-case side thou, i guess to keep it higher up.
Amilla
RHodge
523
Reply #6 on:
February 17, 2007, 05:20:11 PM »
I was thing T-case also,
so Ill go with that
Thanks Guys
Ryan
phloop
Reply #7 on:
February 17, 2007, 06:22:41 PM »
I've had my spacers on the diff's for the last ten years with no problems. I guess it doesn't really matter.
mrfuelish
2862
13
you must have a perception problem.
Reply #8 on:
February 17, 2007, 10:10:47 PM »
on a sammie the front one goes on the t case for x member clearence, the back one gets a longer yoke, on kicks it's kinda hard to put them on the t case
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
