drivers side front axle removal
bentparts
4536
60
I'd rather be Blown AND Injected.
December 28, 2005, 02:43:44 PM »
I've got my front diff housing on thae bench and want to remove the drivers side axle, in order to remove the carrier. Before I attach a slide hammer to the flange to pull it out, is there somthing I should know? Like is there a circlip or some other fastener inside the housing or is it like the ear axle and just a pressed in bearing? I did a search on this and could only find info on the pass side. Thanks
bentparts
4536
60
Re: drivers side front axle removal
December 28, 2005, 03:51:33 PM »
Got It! A little more searching, and a BFH. I still can't get used to all this hammering and pounding, I've been workin' on Harleys too long.
darnold87
351
11
December 28, 2005, 05:25:08 PM »
It just came out using more force, correct? ...shouldn't be anything keeping it in there like a c-clip?
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
bentparts
4536
60
Reply #3 on:
December 28, 2005, 05:43:57 PM »
It had the same c-clip. wire type , as the other side. Couple of whacks, and it came right out.
