Driveshaft clearence
  • 1860 Views
Offline 36zuk
  • 37
  • I love YaBB 1G - SP1!
« on: January 23, 2005, 02:19:45 PM »
I have the RRO trailblazer kit with 3in springs. My driveshaft is hiting my Transmission xmember how can i get that clearence.
« Last Edit: January 23, 2005, 03:02:26 PM by 36zuk »
mudfkr
Re: Driveshaft clearence
« Reply #1 on: January 23, 2005, 04:09:38 PM »
My mates running that same kit in his "90 Sammy and he had to cut the x- member up a bit, not tidy but it works  :-/.
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #2 on: January 24, 2005, 02:54:24 AM »
Not too much help here, not what I've seen somewhere else  :-X :-X ::) ;D
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline track_this
  • 332
« Reply #3 on: January 24, 2005, 07:39:04 PM »
i think rock4xfabrication.com has a high clearance front crossmember if i recall correctly.
shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline rockrat
  • 196
  • Got Ringr
« Reply #4 on: January 28, 2005, 03:02:10 PM »
Yep we do.. replaces the stock x-member completely. 100% bolt in and allows you to cut the stock x-member out and ours goes up and over the driveshaft allowing as much droop as your shaft can physicaly go.
« Reply #5 on: January 28, 2005, 03:43:11 PM »
Is it wide enough to fit a SideKick with a Sammie T-case?
