Would a '90 Tracker rear axle swap in place of a '96 rear axle?
  • 10 Replies
  • 2112 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
Reason I'm asking is because the '96 I'm going to look at this weekend has what the guy calls a whine coming from the rear end.  He thinks it's a bearing issue and has a bearing kit for the axle.  At the same time it's turning 31's with whatever gears came stock on a '96 2 door with the auto.
...however sitting in my back yard is my '90 POS money hole with 5.12's...and I'd be glad to get some money back from it if I could swap the whole damn axle in, get rid of the whine, and get proper gearing back.
Both are 2 door soft tops.  The '90 is a Japanese built 5 speed and the '96 is a Canadian built 3 speed auto.
Yes I know I'd have to regear the front too.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Would a '90 Tracker rear axle swap in place of a '96 rear axle?
« Reply #1 on: March 03, 2006, 07:41:27 PM »
My borderline psychic powers (along with stuff that I learned this week about TracKicks equipped with 3-speed automatics) tells me that the 3-speed automatic will be equipped with 4.625s.  You can jack up a wheel, mark the edge of the flange with chalk or a parts marker and spin the wheel to figure the ratio.
Of course, there may be antilock stuff that must be disabled or transplanted if so equipped.  I have an unknown year rear 4.625 third laying around that has an electrical plug on the case and a sensor ring bolted to the side of the ring gear.  So transplanting a non antilock axle into an antilock truck might make the project not worth doing...
Ack
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: March 03, 2006, 08:13:48 PM »
Would a '96 definately have ABS or was it an option?  This sounds like a pretty simple, low option Tracker, not a LSI or optioned out one.
Basically I just want to know if there's a reason I can't just unbolt everything from the '96's axle and bolt the '90's axle back up in it's place (assuming ABS isn't an issue).
Offline the_maplebar
  • 466
« Reply #3 on: March 03, 2006, 10:17:41 PM »
I'm sure it was an option... It was an option (that I don't have) in my 2002.
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
« Reply #4 on: March 04, 2006, 04:38:55 AM »
A 1996 Auto will have a 4.30 rear ratio. Other than that Ack is right and you can swap the 3rd member or complete axle assy out unless one has ABS and the other does not or just disable the ABS. I would recommend swapping out the 3rd member and if you need a 4.30, 4.62 or 5.12 with the ABS sensor there should not be a problem finding one.
Sean (I'll have the pic's this weekend....really) DeVinney
Offline hobgoblin
  • 224
« Reply #5 on: March 04, 2006, 09:27:14 AM »
Hello,
the brake backing plate,wheel cylinders,hardware and pads are different.
I posted pics....the new ones are 93 the old one is the 90.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #6 on: March 04, 2006, 05:45:18 PM »
Damn! That '90 is in great shape.. ::)
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
« Reply #7 on: March 04, 2006, 07:47:46 PM »
Haha I bet mine looks like that.
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: March 05, 2006, 06:21:11 AM »
Makes me want to keep my '96's axle and just fix whatever is wrong. :P
Yep, I bought the '96.  Little tall for my tastes but it's mine. 8)
Lemme know if this doesn't work:
It's now on 31's.
Offline echojeff
  • 414
  • Lo que sea
« Reply #9 on: March 05, 2006, 06:34:55 AM »
What size tires are those in that picture.  I wonder if 235's would look like that with that much lift.
95 Kick 4dr JLX.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: March 05, 2006, 07:02:26 AM »
Those were 30x9.5R15's.  Your average 235/75R15 would be less than half an inch shorter.
