ECM Question
ECM Question
Rileysowner
39
ECM Question
September 08, 2008, 06:51:32 PM »
I have a '93 Sunrunner and am looking at a '94 tracker that won't run and may have a bad computer. I am not too worried if it won't run because my '93 does. My question is there any difference in the ECM from the '93 to the '94 and could I swap the '93 to see if the ECM is the problem and maybe get it running so I can get it home?
Last Edit: September 08, 2008, 06:53:25 PM by Rileysowner
wheresmyhat
244
16v here I come baby!!!
Re: ECM Question
September 08, 2008, 10:57:29 PM »
shouldn't be a problem as long as they are the same engine.
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
Rileysowner
39
Re: ECM Question
September 09, 2008, 05:57:01 AM »
Both are two door convertibles and I believe both have 8V engines.
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: ECM Question
Reply #3 on:
September 10, 2008, 04:50:53 AM »
Take a look inside, if the boards look the same then it should run. There are something like 70 ECU variants across the Track/Kick model range. Most are minor software variations.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
Rileysowner
39
Re: ECM Question
Reply #4 on:
September 10, 2008, 06:29:15 AM »
Thanks everyone. Sadly, and I mean really sadly, I missed out on this one as someone else grabbed it before I even received a response from the seller. I will just have to keep my eyes open for another in the area.
