tow loop doesn't work very well
  • 13 Replies
  • 2198 Views
Offline Brandon
« on: March 15, 2004, 12:20:29 PM »
this is what happens when you unstick a med. size wrecker How would you fix this?? ???
Offline idaholwb
  • 772
Re: tow loop doesn't work very well
« Reply #1 on: March 15, 2004, 12:34:33 PM »
 Umm, duh?
Hehe!!
:D :D
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Brandon
« Reply #2 on: March 15, 2004, 12:41:12 PM »
hey,it pulled it for about 30ft..the loop broke on the last about the last 2ft.I had to give my Zuk props
« Last Edit: March 15, 2004, 12:41:49 PM by 4g63NT »
Offline idaholwb
  • 772
« Reply #3 on: March 15, 2004, 01:05:26 PM »
 Nice!!
I'm not questioning the abilty of the zuk into question. I'm probably the last one to be explained to, after all, i do own a lwb sammy on 35s!
Hehe!
8)
8)
« Last Edit: March 15, 2004, 01:05:55 PM by idaholwb »
97 Sport
265/70-16s
2" lift
2.0 swap
Offline mrfuelish
  • 2862
« Reply #4 on: March 15, 2004, 01:31:32 PM »
So were you using a chain or a strap? and what happend to the hoop as it went flying?
Offline Brandon
« Reply #5 on: March 15, 2004, 02:29:59 PM »
Chain.Actually,I was jerking on it with the headlights and the fog lights on when I heard a bang and it got kinda dark :-/.My buddy in the wreaker said it looked like my truck was a UFO ;D.I got out and looked and the grill and the fog lights had ejected from my Zuk :o.Took 15min to find them in the dark.The loop had disappeared also >:(.How the he11 do I fix it? ???I thought about fabbing a bumper with new loops but my concern is the airbags...
« Last Edit: March 15, 2004, 02:31:21 PM by 4g63NT »
Offline jagular7
  • 1026
  • Jagular7
« Reply #6 on: March 15, 2004, 02:42:12 PM »
Best way to repair the damage is to strengthen the frame portion if it's necessary. Take 1/4" plate to fit inside the frame horn. Then I'd add a GM hook which uses 3/8" or bigger bolts. I had a set on the frame horns of my Bronco (6000+#'s). Never had a problem. I removed them to add an ARB bumper.
Lenexa, KS
Offline Mike71
  • 1449
« Reply #7 on: March 15, 2004, 02:57:11 PM »
what is that that u ripped off? did u tear off the tow hook? sry im kinda slow i know  ::)
623hp kb cobra sold! 100hp kick new DD :P
Offline Brandon
« Reply #8 on: March 15, 2004, 03:01:37 PM »
Yep
Offline Mike71
  • 1449
« Reply #9 on: March 15, 2004, 03:07:07 PM »
how did the tow hook come off???? isnt it on the frame???
Offline Brandon
« Reply #10 on: March 15, 2004, 03:10:23 PM »
Not to be mean but I explained it above at the top...Donno whether its connected to the frame or not,well its not anymore anyways
Offline Mike71
  • 1449
« Reply #11 on: March 15, 2004, 05:06:50 PM »
eh sry im kinda slow  :-[
« Reply #12 on: March 15, 2004, 05:07:57 PM »
Ya fix it with one of these babys  ;D
8)                                              8)                                      8)
That's how ya do it
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #13 on: March 15, 2004, 06:06:28 PM »
Ya if you have access to a welder, or know someone who has one, its an easy fix.
Just take a piece of plate and weld it behind the frame where the tow hook got ripped off. (this will add support just incase the frame go t damaged by the explosion)  then take a pieces of steel solid core and bend it into a loop then but weld the ends onto the frame.
Or you can do something fancy like WildGoody's D-rings there.  Or you can make a bracket that you can slide a shackle shaft through and just hang a shackle on there.
