5.83:1 ring and pinion Q's
  • 14 Replies
  • 3568 Views
Offline ksa421
  • 382
« on: March 02, 2004, 06:04:10 PM »
I have heard that the 5.83 r&p are not very strong and that you should really try and stay away from them. THe reason behing this is the teeth on them are really small and break easily? Has anyone had this problem or toi anyone who is running them what do you think about them? Also is Calmini the only company that makes lower gear sets for the Sidekicks? Thanks
Jacob
Offline hcgalvin
  • 1695
    • Granite Path
Re: 5.83:1 ring and pinion Q's
« Reply #1 on: March 02, 2004, 08:22:41 PM »
Jacob
Know what? That's what Brent tells me... but I had absolutely NO problems with mine, as a matter of fact I consider them stronger, and I haven't heard in any forum about theirs breaking.
Maybe somebody else can share the light on this?
« Last Edit: March 02, 2004, 08:23:47 PM by hcgalvin »
Heather Galvin
« Reply #2 on: March 02, 2004, 09:26:41 PM »
No troubles out of mine yet :)
« Reply #3 on: March 02, 2004, 10:39:29 PM »
Mine are still in the boxes which have Richmond Gears printed on them.
Offline Speedracer7c
  • 2210
« Reply #4 on: March 03, 2004, 12:16:47 AM »
Richmond makes the gears for Calmini
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: March 03, 2004, 04:34:05 AM »
I have absolutely no complaints about mine.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
lucszuk
« Reply #6 on: March 03, 2004, 09:14:59 AM »
im getting some soon too.... hard to turn 34 with stock gears (ps no i never ended up getting 4:62 gears)
« Reply #7 on: March 03, 2004, 10:04:09 AM »
I'm happy with mine.
Offline TomKat
  • 211
« Reply #8 on: March 03, 2004, 10:50:55 AM »
It is true the less teeth=a weaker gearset. But with the low power output of a Zuk engine it isn't bad. Proper tooth contact and ring gear backlash is crucial to a long gearset life. Improper installation is the culprit of failures, 99 times out of 100.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #9 on: March 03, 2004, 12:59:30 PM »
I have three questions...
1-Dou you can fit 5.83:1 gears in a gv or xl-7 steel 3rd member,with an locker(like ARB's)?
2-What is better, gv or xl-7 3rd member?
3-Do you can fit 5.83:1 gears in a 99 and up GV rear diff?
Thanx
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
« Reply #10 on: March 03, 2004, 09:12:02 PM »
1- Yes, but you may need new side gears (see 2 )
2-Check out Kregs thread on the housings. I just posted links there to articles that will tell you the differences.
3- Beats me, anyone ???
Offline Fredo
  • 416
« Reply #11 on: March 03, 2004, 10:27:33 PM »
Thank you very much!
Fredo
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #12 on: March 04, 2004, 01:39:27 AM »
Well, from ARB's application guide:
Grand Vitara rear requires conversion using Vitara third member assembly
So I'm guessing there's SOME kind of difference, if you need a Vitara rear carrier to install an ARB air locker.  But if you do, then obviously, the 5.83's would also work, and it MAY NOT be necessary to swap, if you're just doing the 5.83's.
Bob
GRVIT
« Reply #13 on: March 04, 2004, 03:21:30 AM »
no problems with mine .I m very satisfied.
Also ,dont know if it helps, I have installed the 5,83:1 r&p s' in my 2001 model Vitara.No problems.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #14 on: March 05, 2004, 06:50:13 AM »
No problem here.  Calimini claims their 30% stronger than stock.
Even though their a higher raito, which usally means more and smaller teeth.  These have fewer teeth and the teeth are bigger in size if you compair the two.
Actual diameter of the pinion is smaller of course but like I said the teeth them selves are larger.
I also had someone tell in their opion they would break, but they never tried them and didn't know anyone who did.  I say go for it.
96 Tracker
32 MTR's Warn 8000i
