Confused about what's behind the timing belt cover
  • 21 Replies
  • 2643 Views
Offline Mike71
  • 1449
Re: Confused about what's behind the timing belt c
« Reply #15 on: December 13, 2004, 03:39:55 AM »
why does mine have no wear marks on it but his has gaping holes? doesnt that mean something isnt aligned right? is that SUPOSED to happen  ???
623hp kb cobra sold! 100hp kick new DD :P
Offline jerryp58
  • 449
« Reply #16 on: December 13, 2004, 07:24:48 AM »
What?  You cover doesn't have the breather holes :o  You need those breather holes.
If you want, I'll trade covers with you, and then I can just cut breather holes in your cover with my special "breather hole template"   ;)
Someone said that when the cover gets oil on it, it warps.  I don't know if that was the cause or not, but mine was definitely exposed to lots of oil and it is definitely warped.  That's why the W.P. pulley and the belt wore holes in it.
« Last Edit: December 13, 2004, 07:25:49 AM by jerryp58 »
Jerry
1990 Geo Tracker,  2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
Offline explosivo
  • 3157
« Reply #17 on: December 13, 2004, 11:38:46 AM »
Wait, you mean there's someone out there that doesn't have warped/gouged out timing belt covers? Huh? :o
omghi2.us[/url]
Offline Mike71
  • 1449
« Reply #18 on: December 13, 2004, 12:16:57 PM »
yah no rust oil leaks or holes anywhere
Offline Speedracer7c
  • 2210
« Reply #19 on: December 13, 2004, 12:18:20 PM »
Yeah, I got to replace mine after the tensioner broke and blew the side of it apart!  :o
Offline jerryp58
  • 449
« Reply #20 on: December 13, 2004, 12:38:04 PM »
Where did you get your replacement and how much $$$ (if you don't mind my asking)?
Jerry
Offline mesjr2004
  • 422
« Reply #21 on: December 13, 2004, 01:16:10 PM »
i wouldnt recomend running without a timing cover.  my son had a strong running 16v w no cover.somthing got between belt and pully and jumpped timing at about 5000rpm, bent all of the valves. i didnt run a cover,now i do
