EFI fuel pressure????
prairie_dog
234
85/413 tin top
October 03, 2005, 08:57:37 PM »
I asked a couple of people what the fuel pressure was in the 1.6's and got answers all over the map
I called the dealership, they said 35-40 psi but I question their answer cus after buying parts from them I realized the new dealer with all new staff didn't know much about zukis or cars for that matter
Anyways I bought a holley inline pump says it's set for 45 psi / stalls at 90
good, bad, I don't know
some educated advice would really be helpful
Steve
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
mrfuelish
2862
13
you must have a perception problem.
Re: EFI fuel pressure????
October 03, 2005, 10:24:37 PM »
I would think that would work, just mount it as close to the tank as possible and if you have a plastic fuel filter make sure it is on the sucktion side of the pump.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
sj416 nz
38
I Love ZUKIWORLD!
October 04, 2005, 04:31:39 AM »
i got a 125psi fuel pump in my suzi but it is a bit over the top
around 45psi sounds about right the fuel regulator will be set a bit lower
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
airtec snorkel RRO coil kit toyota running gear 4.88
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #3 on:
October 04, 2005, 04:34:16 AM »
IIRC 35 to 40 is quoted in the FSM as the regulated fuel pressure for the regulator. A 45psi pump should be OK, the surplus fuel will just go back to the tank.
Last Edit: October 04, 2005, 04:43:10 AM by Rhinoman
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
wildgoody
8134
67
Reply #4 on:
October 04, 2005, 08:45:28 AM »
TBI is 36 PSI, I don't know if the
16V MPI is different
DirtDevil
317
Island4x4.com
Reply #5 on:
October 05, 2005, 08:31:34 AM »
should work fine, im running a carter inline pump, puts out around 50 psi... if i remember correctly haha.. but ya, damn its noisy, sounds like an angry hornet
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
prairie_dog
234
85/413 tin top
Reply #6 on:
October 05, 2005, 10:08:22 PM »
Thanks for the info, I'm renting the engine hoist Friday so with any luck the sami will be runn'n by Sunday, all HI TECH (EFI)
I know I'm a little red neck but I like stuff I can fix, can't rebuild an ECM on your tailgate
Steve
da_tub
307
oops...can we still back up>?
Reply #7 on:
October 06, 2005, 06:51:32 PM »
you better make sure that beer fridge if full.. man ,, i know iwork for cheap.....neeed beer... thats at least a two case job!!!!!
91 four door ,and some stuff
mrfuelish
2862
13
Reply #8 on:
October 06, 2005, 07:48:50 PM »
Engine hoist for a zuk engine? drink more beer and let the air out of the front tires you can lift it out by hand!
da_tub
307
Reply #9 on:
October 06, 2005, 08:50:51 PM »
i know hey... he's such a pretty boy some times[
prairie_dog
234
85/413 tin top
Reply #10 on:
October 06, 2005, 09:45:50 PM »
I put the new engine on the stand by hand, it's not that heavy but if you look at Zukipilot's poll on how tall the average zuki owner is I fall in the "stubby" catagory
The rental is only $25 a day so it should only cost me $12.50 right
Will post pics when it's running, I painted almost everything & polished the TBI intake tube
Steve
PS maybe the little saying under my info will finally come true
zaggy
1134
2
Reply #11 on:
October 07, 2005, 07:16:31 AM »
Shouldn't that old saying be...........
Stand back she'e gonna blow! (joking guys stay calm)
Zag
darnold87
351
11
Reply #12 on:
October 07, 2005, 05:13:22 PM »
I run a 1989 1.6L 8-valve in my samurai. I used a NAPA fule pump part# TFP2P74028 (~$70). This is same as AutoZone part# E2000 (~$99.99). They say right on them: 90psi. This is ok (even without a regulator) if you run your fuel return line (very important). Good luck with everything!
ps - they're a bit noisy. mount it in rubber and try not to mount it on the body, go for the frame.
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
