Electric rad fan always running
  • 1556 Views
Offline TysonS
  • 383
  • www.funinbc.com
« on: September 20, 2006, 06:08:18 PM »
my grandpas 1997 trackers electric fan start to run right once you up the key in the ignition and will always run.  And his airconditioning is not working?  what could cause this to happen.  I'm asuming loose or not pluged in wires.
thanks again
  • 6571
  • 66
Re: Electric rad fan always running
« Reply #1 on: September 21, 2006, 08:18:00 AM »
thanks again
Posibly a sensor problem on the A/C system causing it to go into a 'safe' mode. Go to Autozone or some place that will scan your car for free and see what codes, if any are set.
Good Luck, Eric
Offline bzzr2
  • 1011
« Reply #2 on: September 21, 2006, 09:01:43 AM »
my fan would not shut off when what the dealer called was the fan clutch, it was seized and the fan just never stoppped turning...  dunno if your problem could be this or not...
09 taco reg cab short box 4x4
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« Reply #3 on: September 22, 2006, 07:54:45 AM »
Mine is always turning slowly but that is because it is being turned by the air being pulled through the radiator by the main engine driven fan.  I don't think mine kicks in otherwise even though my AC works fine.  Maybe yours is doing that?
