Electrical issues - battery arc
Zuki One
441
July 04, 2006, 10:23:26 AM »
So i was just movin the zuki around the yard! And i forgot the battery was unstrapped, then i saw this stump taunting me so i put it in 2lo and ran it over it was all good until i came down the backside the engine died. So up comes the hood and i see the battery laying on the intake arced and dead so i put the charger on the battery overnight, so now the battery is holding a charge but im getting that stupid clicking you know like the classic starter problem!
why wont this start :'(
P.S. im back and its been awhile!
"Sooo What shop built your rig?"hahahahhahahah
www.cardomain.com/memberpage/607888/1
reb
195
Victim of CRS--Can't Remember Anything.
Re: Electrical issues - battery arc
July 04, 2006, 11:40:26 AM »
I would check all the normal things: Are the terminals clean?; Is the ground connection good?; Are the cables ok?; Is the acid level ok?; etc. The battery might have a problem. The battery just went south on my tractor yesterday. I determined that by monitoring the voltage on the terminals while the CFO tried to crank it. The voltage dropped to almost zero when she turned the switch.
Rhinoman
4502
36
Bend it, Break it, Fix it
July 04, 2006, 11:40:51 AM »
A big discharge might have bent the plates. Have you checked the electrolyte level? Also check that you haven't damaged the cables.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
Zuki One
441
Reply #3 on:
July 04, 2006, 12:07:27 PM »
uhmm my battery drops to 12.4 dcv and all my cables are good ! im jus gettin that f|removethispart|@ckn clickn noise i haven,t checked the fluid and itsa 6mnth old die hard? i will check with a deep cycle here in a few
