Where would I get 2 LO for transfer case?
  • 8 Replies
  • 3024 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« on: September 25, 2005, 10:09:01 AM »
Does anyone know  of somewhere to get a new shift sheet that has a 2 lo option other than rocky road.
« Last Edit: September 25, 2005, 10:15:58 AM by bashzuk »
Mean Green Wheeling Machine
Offline locjaw
  • 2045
  • 22
Re: Where to get 2 LO for transfer case
« Reply #1 on: September 25, 2005, 10:16:13 AM »
you dont need a kit for the sammi all you do is leave the center detent ball out , but......
dont do it, it aint worth it  >:( mine started to slip into0 the 2 wd shift pattern all by itself(especally when you dont want it to).
i put the ball back in, problem solved!
jason
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: Where would I get 2 LO for transfer case?
« Reply #2 on: September 26, 2005, 11:39:25 AM »
I would go with a twin stick type shifter . what for a kick or sammy?
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #3 on: September 26, 2005, 05:43:15 PM »
Hey Stan, PM me if you know where I can get a twin stick for a Tracker transfer.. ;)
Bill
Offline bashzuk
  • 784
« Reply #4 on: September 26, 2005, 06:26:23 PM »
This is for a sammy. twin stick is patented and I have no fabrication skills.
Offline bhaugen
  • 140
« Reply #5 on: September 29, 2005, 07:32:01 PM »
Here is a good write up on how to do it.
http://www.izook.com/tech/samurai/drivetrain/2wdlow/2wdlow.htm
I am running the 2wd low and it works fine.  It is great, not perfect, but it works.  Not as good as a Twin stick, but hey it works, and I am not going to go through the pain to make a twin stick.  I have never had mine jump out of gear ???
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #6 on: September 30, 2005, 02:41:30 AM »
Don't you have manual hubs, that's real easy 2wd Low  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline LiftedSuzuki
  • 27
  • Got Rocks?
« Reply #7 on: September 30, 2005, 02:41:21 PM »
2nd that  :P -David-
'87 Zuk, RR 8" Trailblazer Lift(SPOA), Stage 2 OTT Steering, 31x11.5 Wildcat EXT's, Welded Rear, 4.16 T-Case, Spidertrax Front Tube Bumper, Warn 8000 Winch, Calmini Header, And A RR Rear Crawler Bumper With Rock Sliders And Swing Away Tire Carrier With Hi-Lift
Offline 37kicker
  • 319
« Reply #8 on: October 01, 2005, 01:40:28 AM »
patent,  for a twin stick????      i am building a dual shifting kit for a sammy    sorry  for the confusion.   I all so  have dual shifters for kicks ! ;D ;D
