Engine swap 1300-1600 radiator hoses
  • 1781 Views
Offline thedeep
  • 50
« on: January 12, 2006, 03:46:53 AM »
My Sami hoses do not appear to work with the 1600 engine. I assume I need to get a set of Tracker hoses (94)? Thanks.
Re: Engine swap 1300-1600 radiator hoses
« Reply #1 on: January 12, 2006, 08:16:31 AM »
I put a 1.6 head on a 1.3 engine and
used the same radiator hoses, what is different?
A 1.6 engine has a steel lower section for the
hoses to slip onto, that might be different, it's
attached to the frame on a SideKick
  • 6593
« Reply #2 on: January 12, 2006, 08:21:50 AM »
Did you try it? The Samurai hoses (should) work with a 1.6 8-valve swap. Not sure on the 16-valve.
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #3 on: January 15, 2006, 06:56:06 AM »
On mine it worked fine ( only had to modify the radiator for the SC, but for standard it would not have been a problem. )
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
