help with aftermarket coil install(with pics)
1bigtracker
3409
F*** trail rated, try trail tested
July 13, 2005, 05:55:20 PM »
Ok some body tell me what wire is the positive(+) and negative(-) so i can put on a accel coil. One wire is brown with white tracer(would think is positive) and one is black with a white tracer(would think is negative). and yes i have searched this with no luck(mabey thats just me)
thanks, Stu
 ÂÂÂÂÂÂÂ
wildgoody
8134
67
Re: help with aftermarket coil install(with pics)
July 13, 2005, 08:06:37 PM »
You could try looking on the old coil,
many times the polarity is marked
Rhinoman
4502
36
Bend it, Break it, Fix it
July 14, 2005, 05:06:00 AM »
Black/White is usually a positive ignition supply on Jap stuff. The brown and white is more likely to be the switched side (-ve). If you do a search for schematic, theres a link to another site that has the wiring diagrams. If you can't find it I'll check when I get home.
Edit:
Black/White is +ve, Brown/White is -ve. I found the info on
http://www.suzukiinfo.com
Last Edit: July 14, 2005, 05:16:51 AM by Rhinoman
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
zaggy
1134
2
Reply #3 on:
July 14, 2005, 06:48:38 AM »
I'll check my manual and get back to you
Zag
zaggy
1134
2
Reply #4 on:
July 14, 2005, 10:02:12 AM »
Arrgh
No wiring for the engine bay in the Haynes manual...but I think Rhinoman is correct
Zag
1bigtracker
3409
Reply #5 on:
July 15, 2005, 05:48:46 PM »
I'm very busy right now dealing with the city and am not going to be able to get this for atleast a few more days, but
it will
get done with more pics. thanks everyone
Stu
 ÂÂÂÂÂÂÂ
