Glue !!!
Glue !!!
Mac0
91
Glue !!!
April 15, 2004, 01:24:17 PM »
Would anyone have any ideas on how to get that spray on glue off of the floor ?? The guy who had this thing before me used that spray on stuff for some cheap cut yourself to fit carpet. Any ideas would be great --- thanks Mac0
1bigtracker
3409
F*** trail rated, try trail tested
Re: Glue !!!
April 15, 2004, 01:36:58 PM »
i took the stock stuff off with fire. heat it put and start scrapin. dunno if it will work on that. if its gooy then mabey try brake clean.
stu
 ÂÂÂÂÂÂÂ
92Sidekick4x4
1456
Spencer Atkinson, 92Sidekick4x4
Re: Glue !!!
April 15, 2004, 01:56:24 PM »
id sugest either solvent or even carb cleaner
my lug nuts require more torque then my engine makes
explosivo
3157
I'm in the northern part of that one state.
Re: Glue !!!
Reply #3 on:
April 15, 2004, 02:09:02 PM »
Some sort of paint stripper, possibly? Either that, or use a torch like Stu said and scrape it off.
omghi2.us[/url]
Its a ZUKI thing. Doing more with less than less with more.
" -- HotRod
Mike71
1449
Re: Glue !!!
Reply #4 on:
April 15, 2004, 02:15:13 PM »
id use a solvent and soak the sh$t outa it..just goto like a paint place or something and ask what kinda harsh solvent they reccomend
623hp kb cobra sold! 100hp kick new DD
Agent Orange
711
Re: Glue !!!
Reply #5 on:
April 16, 2004, 12:08:32 PM »
try acetone
Bfunk
406
2
Re: Glue !!!
Reply #6 on:
April 16, 2004, 01:02:21 PM »
Spray on gasket remover, but be careful, to much will take off paint.
Brian
nuts4hotwheels
169
Black Sunshine
Re: Glue !!!
Reply #7 on:
April 16, 2004, 11:01:00 PM »
They make this stuff called "Goof Off". I have used it to remove adhesive from stickers and it says that it will remove a whole list of stuff, like tar and adhesives.
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Mac0
91
Re: Glue !!!
Reply #8 on:
April 17, 2004, 10:56:08 AM »
Ya - babe GOOF-OFF is the stuff.. Put it on and it is melting the glue away but leaving the paint.
Thanks for all the reply's ------ Mac0
1bigtracker
3409
Re: Glue !!!
Reply #9 on:
April 17, 2004, 11:51:46 AM »
ok 1 point for sidekickmuddog
 ÂÂÂÂÂÂÂ
Mike71
1449
Re: Glue !!!
Reply #10 on:
April 17, 2004, 02:08:30 PM »
i still wanna see u go after ur interior with a torch
Mac
407
Toys, Toys, Toys
Re: Glue !!!
Reply #11 on:
April 17, 2004, 02:51:26 PM »
I don't know where you live, but if you get a real hot day, the heat from the sun should be enough to loosen it up, that is how I got mine off, before I did the bed liner inside.
Mac
Bobzooki
1754
2
Web Wheeler
Re: Glue !!!
Reply #12 on:
April 18, 2004, 12:49:33 AM »
Methyl Ethyl Ketone.
MEK will remove ANYTHING, including your fingers and toes if you aren't careful!!!
I just saw that they sell it in the paint section at my local Home Depot...
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
