Building a Snorkle???
  • 13 Replies
  • 4300 Views
Offline breadbox
  • 119
  • Me Like Doughnuts!!
« on: February 03, 2005, 05:01:05 PM »
Has anyone built a snorkle for thier Sammy, I would like to make one but don't know where to start.  A direction would be nice, a list of parts, and some pics too.  Thanks. ;D
1.3 ltrs of FURRY!!!!!!
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Building a Snorkle???
« Reply #1 on: February 03, 2005, 09:18:46 PM »
Hey,
It's in French but with a lot of pic's might be helpfull:
http://www.gadoueweb.com/meca-suz/Preparation/Samourai/snorkel.htm
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline breadbox
  • 119
« Reply #2 on: February 04, 2005, 02:19:03 AM »
Cool, thanks, the pics help but I wish I could read French.
Any others??
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: February 04, 2005, 02:30:58 AM »
MOst sammy drivers make them out of waste pipe from your local DIY store with a couple of zip tags holding it on around the car radio antena. you can get the push fit connectors and bends as well
Usually cut out the little grill part on the bonnet. The way to test it is have it ticking over and put your hand over the end, if it stalls you have a snorkel.
Only down side is you may need to disconnect during the winter as you will suffer from carb freeze
Markyb (UK)
UK Vitara JLX SE
Offline breadbox
  • 119
« Reply #4 on: February 04, 2005, 03:53:55 AM »
So when you build it do you connect directly to the carb or do you go through the air filter box??  I would think you would go through the filter.   ??? ???
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: February 04, 2005, 04:59:55 AM »
You definitely want to keep an air filter in there - but if you can manage to switch it to a K&N filter, it would be a big plus.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #6 on: February 04, 2005, 05:00:43 AM »
the ones i have seen go through the air filter box but be sure to have a tube of silicone handy to seal any drain hole up
Markyb (UK)
UK Vitara JLX SE
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #7 on: February 04, 2005, 06:41:41 AM »
i built one for my tracker i don't know if this will help but here r some pics.
« Last Edit: February 04, 2005, 06:42:07 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
mudfkr
Re: Building a Snorkel???
« Reply #8 on: February 04, 2005, 06:45:02 AM »
Here's one I built for a mates 413.
It's built out of exhaust bends that we cut to the correct angles and weld together. The rubber bends thru the guard are from a Nissan Skyline inter cooler.
You can use PVC if you don't have access to a welder  but I like steel as it takes a beating and doesn't deteriorate in the sun like PVC.
The lid on your air box has a neoprene seal which is probably stuffed so take it out and replace it with some silicone O-ring rubber to make sure you 100% water tight and as Mark said fill the drain hole in it, I used hot melt glue for that.
HTH Shane
Offline breadbox
  • 119
« Reply #9 on: February 04, 2005, 10:23:07 AM »
tracker8wr, what did you use for the top?  I need something to keep the rain from running down the snorkel.  I live on the WET side of the Cascade Mts. in Wasington State, we get some pretty good rainstorms.  What size pipe should I use??
« Last Edit: February 04, 2005, 10:27:48 AM by breadbox »
Offline Cwkick
  • 888
« Reply #10 on: February 04, 2005, 10:53:51 AM »
IIRC  It is a rain cap for an outdoor electical connection.
Cwkick
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #11 on: February 04, 2005, 11:20:51 AM »
Offline breadbox
  • 119
« Reply #12 on: February 05, 2005, 01:59:07 AM »
WOW, that was really cool, Thanks, a lot. :D
Offline tracker8wr
  • 568
    • my home page
« Reply #13 on: February 05, 2005, 09:09:12 AM »
it is an out door electrical cap i was 1 1/2 or 2" i don't remember right now but i can measure it tomarrow. i do have a bit of air restriction an my motor complains about it but it functions so i added in a cutoff under the hood for street operation but it is not shown in the pics.
« Last Edit: February 05, 2005, 09:09:54 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
