exhaust fumes
exhaust fumes
cstello
33
exhaust fumes
November 22, 2008, 04:02:25 PM »
Does anyone have any good ideas to keep the exhaust from coming back in the cab when driving?
Drone637
8121
116
Evil Cow
Re: exhaust fumes
November 22, 2008, 04:29:51 PM »
Where does your exhaust end at? I had this problem when the exhaust was broken in front of the rear axle. Once I routed it out the back end with a slight down pipe the problem went away.
cstello
33
Re: exhaust fumes
November 22, 2008, 04:49:59 PM »
Mine is routed out the back with a straight pipe
Drone637
8121
116
Evil Cow
Re: exhaust fumes
Reply #3 on:
November 22, 2008, 04:51:42 PM »
Try throwing a 90 degree bend on it to vent the pipe down at the ground instead of blowing straight out the back.
Also, make sure you don't have an exhaust leak under the cab.
Merlin93
170
4
Re: exhaust fumes
Reply #4 on:
November 22, 2008, 09:57:16 PM »
Quote from: cstello on November 22, 2008, 04:49:59 PM
You may have discovered why the stock tailpipe is shaped the way it is. Others with straight exhaust tips have made the same observation as well.
urbanwheeler
696
I Love ZUKIWORLD!
Re: exhaust fumes
Reply #5 on:
November 22, 2008, 10:13:57 PM »
I have always heard the exhaust exits on the rear corner of suzukis, as well as on other suvs like 4runners, so the exhaust gasses don't get caught in the turbulence caused by the squared off rear end of the truck.
