Transfer case won't go to 4WD
  • 1 Replies
  • 553 Views
Offline cavemann
  • 9
  • Stock '90 and HIGHLY modified '88.
« on: June 18, 2021, 07:07:46 PM »
 Anybody got a suggestion on why my 90 model bone stocker transfer case wont shift into 4WD? I have Hi 2 WD and neutral. Replaced shifter sheet just in case that was the problem. Didn't help. Seems like the shifter shaft may be locked up. Wondered if I might just pull the front cover with the shifter housing or should I pull the transfer case and tear it down? Any advice is greatly appreciated.
Re: Transfer case won't go to 4WD
« Reply #1 on: June 20, 2021, 11:28:53 AM »
Isn't 4H in between 2H & N?  What happens when the shifter is in 4H?
