Fed ECU in a CA Sidekick
  • 1862 Views
Online RJkick
  • 634
« on: September 15, 2009, 12:19:05 PM »
Does anyone know if running a Federal ECU in a CA '92 4 dr sidekick will cause any issues
Lower mileage
stalling
etc.
I know it will cause a CEL code 53 which tells me it is the wrong ecu
Any Thoughts
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Fed ECU in a CA Sidekick
« Reply #1 on: September 17, 2009, 12:04:03 PM »
« Reply #2 on: September 17, 2009, 12:46:44 PM »
I should think that you can run a Fed ECU in a California car, my understanding was that the CA car has an extra sensor for EGT so a CA ECU in a Fed car would throw a code.
There was some speculation that CA and FED was determined by the presence of an additional ground in the CA car. If not it will most likely be by configuration resistors inside the ECU.
