Feels like the brakes are on in 4WD
g35-coop
31
February 09, 2012, 07:47:47 AM »
Why does it feel like that? Every time I push in the clutch it stops like im putting on the brakes.
*Image Removed*
Jonny Rash
1094
21
Too many Samurais, too many little boys!
Re: Feels like the brakes are on in 4WD
February 09, 2012, 07:54:18 AM »
Are you turning when you are pushing in the clutch, ie turning into a parking spot? If so, it is because the front and rear axles are binding up.
35 years of Samurai ownership, and I still have my very first one.
g35-coop
31
February 09, 2012, 08:09:47 AM »
no I can be pointing straight and it happen.
*Image Removed*
fordem
4331
170
Reply #3 on:
February 09, 2012, 08:45:54 AM »
Are the front & rear tires the same size and general wear condition?
Jonny Rash
1094
21
Reply #4 on:
February 09, 2012, 08:59:14 AM »
Yep, sounds like he has different sized tires on it.
jason hutchison
495
5
ZUKIWORLD Staff
Reply #5 on:
February 09, 2012, 09:24:42 AM »
Gremlins... was your car assembled in Japan?
g35-coop
31
Reply #6 on:
February 09, 2012, 10:18:55 AM »
Yes all tires are the same size.....
*Image Removed*
mrfuelish
2862
13
you must have a perception problem.
Reply #7 on:
February 09, 2012, 10:50:14 AM »
ah Twenty Questions, I'll play, Has it always been like that?
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
g35-coop
31
Reply #8 on:
February 09, 2012, 12:29:00 PM »
haha....no it hasn't
*Image Removed*
jzap
515
2
How difficult can it be?
Reply #9 on:
February 09, 2012, 03:18:19 PM »
Have you checked tire pressure. Even a small difference in tire pressure can cause enough of a size difference to bind up an axle in 4WD.
Jim Z.
96 Tracker
66 Apache camper
g35-coop
31
Reply #10 on:
February 09, 2012, 03:39:27 PM »
Ill check tonight. Im not running a z-link or anything like that and have a little lift could that be the problem?
*Image Removed*
Skyhiranger
3734
122
I don't buy, what I can build
Reply #11 on:
February 09, 2012, 05:30:05 PM »
Are you 100% sure you have the same gears in both axles?
Have you put the vehicle up on jackstands (or at least had all 4 tires off the ground), with it in 4wd and spun each tire to see if there is any excessive drag on any tire?
Last Edit: February 09, 2012, 05:31:38 PM by Skyhiranger
moonzuk52
18
Reply #12 on:
February 09, 2012, 10:59:56 PM »
it might be the bearing.mine just made little noise then trow me in the ditch.haha pion stoped. just a thought.
88 Sammy coils front,rear. 8:1 tcase,5:12,and 37-12.5-16.5 on double beadlocks. arb front spooled back.
96 X90
00 Vitara
