Finally checked out all the video vault has to off
  • 10 Replies
  • 3071 Views
Offline Samurai_Hamster
  • 28
  • 87 Octane knocker of a motor.
    • Samurai Hamster
« on: September 24, 2003, 01:36:07 PM »
The Zuke is on its way out.  Getting a vehicle that will behave and be supported by the dealer.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: Finally checked out all the video vault has to
« Reply #1 on: September 24, 2003, 02:03:59 PM »
Blown a motor? How do you even do that? No wait, I dont want to know! ::)
Mike
BTW- Chunk really is that laid back! Nothin phases him. Right before Some extreme obstical he will light a smoke and hang one arm out the window (rodeo style) and just drive. Gota love'm
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #2 on: September 24, 2003, 02:10:31 PM »
Hamster wrote: I also checked out Hagen raisin' cain on Golden Spike, too bad its small but the sound gives creedence to his motto "red line, all the time"
Its hard to tell because its so small but that is Double Whammy. Its a lot harder than it looks. We will see if it was luck or talent when I return next year. :P
Mike
« Last Edit: September 24, 2003, 02:11:35 PM by Mikerpm4x4 »
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #3 on: September 24, 2003, 02:21:22 PM »
OK PC EXPERTS ::) THIS IS WHAT I GET WHEN I TRY TO WATCH STUFF IN THE VIDEO VAULT (Windows Media Player cannot play this file. Connect to the Internet or insert the removable media on which the file is located, and then try to play the file again.) OK I AM CONNECTED TO THE INTERNET OBVIOUSLY CAUSE I'M HERE :-/ ANY HELPFUL HINTS FOR A CONFUSED, FRUSTRATED,ZUKE FAN THAT WANTS TO SEE SOME VIDEO'S  ;D MATTY D.
« Reply #4 on: September 24, 2003, 04:25:04 PM »
Did you download and save the Videos
to the hard drive? if so they should play.
if you play them from the web directly it might
ask you for a web conection if you are offline.
Do you have DSL or Cable?? or Dialup like me  :'(
  • 28
    • Samurai Hamster
« Reply #5 on: September 25, 2003, 01:19:39 PM »
Ok, howabout Heather Hagen, how does she approach an obstacle?  Smoke and arm out, or sheer panic?  Or does she take after you and mash the gas and go for it?
  • 28
    • Samurai Hamster
« Reply #6 on: September 25, 2003, 01:21:41 PM »
NYSIDEKICKER........check your media player settings. I have mine buffer the entire clip into memory and it lights right off w/o having to download it
Check your version too.......FWIW I have version 9
ALso verify which file types you allow it to play.
Offline Z3bra
  • 273
« Reply #7 on: September 25, 2003, 02:23:31 PM »
NY_Sidekicker, it sounds like a connection timeout or for some reason you can't establish a connection to the server because it's too busy (not too likely).  Best bet is just save the file via the good old right-click/save target as method and view it from your harddrive.  If you get a timeout there then I'd suspect that for some reason your ISP has some routing issues they need to fix.
  • 2274
« Reply #8 on: September 25, 2003, 02:45:02 PM »
OK THANKS FOR THE INFO..I'LL TRY TO WORK IT OUT THIS WEEKEND WHEN I HAVE A BIT OF TIME ::)
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #9 on: September 25, 2003, 11:32:36 PM »
She always seems calm and just seems to cruse through. If that dont work then its pretty much mash the gas.
Mike
  • 28
    • Samurai Hamster
« Reply #10 on: September 26, 2003, 01:28:10 PM »
So does redline all the time run in the family? ;D
