31's fit on stock aluminum rims?
  • 1411 Views
Offline westvilleguy
  • 53
« on: January 07, 2007, 05:08:47 PM »
will 31 10.50 15 tires fit on stock aluminum 15" rims of a 91 tracker the aluminum look smaller than my stock steel ones might just be the way they look
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: 31's fit on stock aluminum rims?
« Reply #1 on: January 07, 2007, 09:01:47 PM »
I fit 32x12.50's on stock samurai rims 15x5.5 so I'm pretty sure that you can do it might have a problem with rubbing. but since I don't run a tracker I'd say give it a go and see what happens.
Mean Green Wheeling Machine
Offline ROSS
  • 1412
« Reply #2 on: January 07, 2007, 09:04:02 PM »
IF THEY RUB. STICK ON SOME SPACERS
Offline da_tub
  • 307
« Reply #3 on: January 07, 2007, 09:05:46 PM »
they'll rub,, alot... and aren't spacers hard on wheel bearings...
91 four door ,and some stuff
Offline kirknd4spd
  • 333
« Reply #4 on: January 07, 2007, 10:47:46 PM »
spacers are not necessarily hard on bearings. it all depends on how far the wheel actually sticks out. the farther it sticks out, the harder it is on bearings. and yes, you will need spacers with 31's on stock wheels. i think i got mine from spidertrax, if i remember correctly. they are 1" spacers. and remember that if you cant find spacers specifically for a trackkick, look for sammy spacers. they are the same bolt pattern.
89 Sidekick - 2 door soft top, 1.6, auto, 4x4, 3" suspension lift, 31x10.50's on 15x8 Mickey Thompsons, long tube header
