Fixing the Tachometer??
  • 12 Replies
  • 3063 Views
95XL7
« on: May 11, 2004, 09:03:39 AM »
Does anyone know how to make a 4 cylinder tach work with a 6 cylinder? Mine is off about 500rpm at idle and at 2500 reads 3500rpm. Is there a way to put a resister inline? I want to keep the factory tach to keep everything stock looking.
SpinalTap
Re: Fixing the Tachometer??
« Reply #1 on: May 11, 2004, 09:08:32 AM »
Sorry can't help...but it does remind me of when I stuffed the 327 in my Vega...the stock 4cyl tach read double the actual revs  :D
  • 6587
« Reply #2 on: May 11, 2004, 10:53:49 AM »
You're using the XL7's ECM tach output and pluggin into the '96 tracker tach, right? Since the newer tach is just a DVM of sorts, this should work. The correct resistor in series with the tach should work. Right? I still need a newer cluster to finish this bit up on my swap...
Aren't the 'little things' a blast? :)
95XL7
« Reply #3 on: May 11, 2004, 11:02:27 AM »
I have a 2001 gauge cluster but its totally bigger than 95 and down,i bought it off ebay for testing purposes. I think if theres a resistor somewhere it's built into the tach head itself?
« Reply #4 on: May 11, 2004, 12:19:38 PM »
I tried to connect the OEM tach lead to the
MegaSquirt EFI unit, it freaked out the Stock
ECM and would not run, I think the Tach uses
the pulses from the ECM ground on the coil, so
what you really need is to remove 2 of the ignition
pulses from the tach, OR print out or replace the
faceplate on the tach so the RPM reads correct.
This was an idea I had to correct the bigger tires
and changed speedo readings, just need a clean way
to replace the stock faceplate, like the Ricers do with
colored speedo faceplates.
Anyone have any good ideas of how to do this ???
95XL7
« Reply #5 on: May 11, 2004, 11:27:06 PM »
In the process of swapping in the tach from the 2001 into the 95 guage cluster. Not a direct bolt in but do-able
using parts from both clusters.....what a cluster F..k!!
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #6 on: May 12, 2004, 02:06:27 PM »
  :o  PUN  :o
95XL7
« Reply #7 on: May 12, 2004, 02:16:31 PM »
Didn't work :-/ >:( :'(
Offline 99Trackerconv
  • 430
  • I love my Tracker
« Reply #8 on: May 12, 2004, 11:44:27 PM »
What? The cluster or the pun. LOL ;D
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
« Reply #9 on: May 13, 2004, 01:33:39 PM »
Wouldn't be easier to buy an aftermarket Tach?     6-10 inch ;D
TITAN
« Reply #10 on: May 13, 2004, 01:35:56 PM »
DUDE WATS WITH UR SIGN!!?!?!?!?!?!?
  • 2274
« Reply #11 on: May 13, 2004, 04:01:50 PM »
THATS HIS PIMPING RIDE FOR THE STRIP ON SATURDAY  NIGHT  :P
« Reply #12 on: May 13, 2004, 04:49:36 PM »
Just Goofin with my EDIT Program. ;D
Thats about as high tech as I get.
So Far ;D
