Also on the right you can see Im using Wurth Boots.They just cant be damaged. Incredible protection for the joints.
Where'd you get the boots? I've had tons of problems with the cheap replacements that I get from Carquest tearing under normal daily driving.
Give me 10 min and I ll show you more about them ..I guess you can find in every store that sells automotive parts.They are not cheap but they worth the money.Unless a CV ' breaks,you re going to have them 2-3 years.The CV boot is made by Wurth,a company that makes special tools,many things mainly for automotive use.The product series is Wurth FIRSTEC and its number is Art-Nr : 820 500.http://www.to4x4.gr/gallery/albums/album40/DSC00683.jpghttp://www.to4x4.gr/gallery/albums/album40/DSC00686.jpghttp://www.to4x4.gr/gallery/albums/album40/DSC00687.jpghttp://www.to4x4.gr/gallery/albums/album40/DSC00688.jpghttp://www.to4x4.gr/gallery/albums/album40/DSC00689.jpgYou ll notice that they are much bigger than stock ones,you can cut them where you this is best,I cut 1" from the back and I dont use its fasteners,but heavy duty ones.I f you check the photo of the spanish axle shaft a few posts back you  see.
The best way to reduce the CV angle would be to get radical and make a center mounted R&P. That would make your shafts longer and the angle less...If I remember right, doesn't Mike have a Calimini proto type of one?
You can make a center diff without touching the rest of the front suspention.It's just the drive line. It really doesn't have anything to do with the front "suspention". As long as the angles of the CV's are the same there souldn't be a problem. And if there was it would be a vibration.I was just talking about making room for the third member to fit.
